only run once
foscolino
Domoticz version: 2.20
only run once
Post by foscolino »
Hello, i have this script to check if light is on every first, second, third hours and after send mail notification, but the problems is a "time trigger" and run every minutes. :?
is it possible run this script only run once, not every minutes!
thanks a lot.
if (otherdevices['S1 - Antibagno - 192.168.20.73'] == 'On' and difference > 3600 and difference < 7200) then
   commandArray['SendNotification']='Luce Antibagno#Attenzione, Luce accesa da più di 1 ora!'
   print('Luce Antibagno accesa da più di 1 ora')
elseif (otherdevices['S1 - Antibagno - 192.168.20.73'] == 'On' and difference > 3600 and difference < 10800) then
   commandArray['SendNotification']='Luce Antibagno#Attenzione, Luce accesa da più di 2 ore!'
   print('Luce Antibagno accesa da più di 2 ora')
elseif (otherdevices['S1 - Antibagno - 192.168.20.73'] == 'On' and difference > 3600 and difference < 14400) then
   commandArray['SendNotification']='Luce Antibagno#Attenzione, Luce accesa da più di 3 ore!'
   print('Luce Antibagno accesa da più di 3 ore')
Re: only run once
foscolino wrote: Wednesday 18 November 2020 7:51 Hello, i have this script to check if light is on every first, second, third hours and after send mail notification, but the problems is a "time trigger" and run every minutes. :?
It is not possible to prevent the triggering of a time based classic Lua script but you can prevent that the notifications are send and/or the prints going to the log by using the logic from the code below.
local atMinute = '07'
if os.date('%M') ~= atMinute then
    print ('no execution required')
print ('I will process rest of the script logic now')
.. or use the dzVents Lua framework where you can set the script to only execute once per hour , -day ,-week, etc..
foscolino
Re: only run once
Post by foscolino »
Hi waaren, thank you very much for your feedback, but I don't understand the logic you wrote :?
local atMinute = '07' is a random value?
if the date minutes is about or equal to seventh minute the script not work, correctly ? ;)
thanks for you support
Re: only run once
foscolino wrote: Wednesday 18 November 2020 9:03 local atMinute = '07' is a random value?
Yes atMinute can be anything from '00' to '59'
No. If the date minutes = '07' the rest of the script will be executed. If the date minutes are not '07' the script will stop without executing the rest of the script
foscolino
Re: only run once
Post by foscolino »
Hi waaren,
thank you very much, now I understand ;)
