Switch from Raspberry to NAS
Posted: Thursday 12 November 2020 14:35
by Fox27
I run Domoctiz for several years on a Raspberry. Now I have a new Synology NAS and want to move the whole Domoticz system to the NAS. Installation of Domoctiz was easy and without a problem.
For the Z-wave network, I use a Aeotec Z-wave stick Gen5. As I already built the system for several years there are now 16 devices (Nodes) connected via the USB-stick.
As soon as I connect the USB-stick to the NAS it reshuffles the NOD-id’s and all the “names” are empty.
Is there a possibility to copy this information from the Raspberry to the NAS?
Is it possible to copy the databases to the NAS zo I still have my history on the devices?
Re: Switch from Raspberry to NAS
Posted: Thursday 12 November 2020 15:17
by waaren
Fox27 wrote: Thursday 12 November 2020 14:35
Domoticz uses only one database ( domoticz.db ) and that can be copied and used on the NAS. You might need to change the usb ports for the hardware connected to USB
Posted: Thursday 12 November 2020 19:55
by Fox27
Are the nod-id's and names than also updated. Is this also stored in the database?
Posted: Thursday 12 November 2020 20:03
by waaren
Fox27 wrote: Thursday 12 November 2020 19:55
Not 100% sure about this but from memory (when I switched from NAS to Raspberry and later from Raspberry to NUC), I think some information is in the stick but you might loose the node names.
Posted: Saturday 21 November 2020 9:56
by Fox27
Decided not to switch to the NAS because DSM7 will not be supported (yet). Instead I upgraded the system to a Raspberry pi4 with a SSD drive (to get rid of the SD-card). The systems runs now completely via the SSD-drive (boot and operational).
Posted: Saturday 05 December 2020 20:45
by Dimmi
I am making the move from NAS to Raspberry Pi 3B
Since you tried the move with the Z-wave stick.
I see that you had the problem of empty nodes, but did the nodes work, or not?
I remember I had the empty nodes before, often after the NAS shuffled the USB ports again after a reboot.
I hope to make the step from the NAS (2020.1) to the RasPi (2020.2) without having to rebuild the Z-wave network.
