item.statusCode = 28?
Posted: Tuesday 10 November 2020 13:58
by Number8
Using async http, sometimes I get a timeout error. statusCode reports code 28 whilst statusText reports "Timeout was reached" (which is what is expected). I would expect code 408 instead of 28. Am I wrong?
Re: item.statusCode = 28?
Posted: Tuesday 10 November 2020 14:23
by waaren
Number8 wrote: Tuesday 10 November 2020 13:58
From the sendsync() 6 docs: “If the statuscode is 100 or higher, it is a real HTTP status code returned from the server; if it is between 0 and 99, there was an error sending the request.”
Errors 0-99 match curl errors: 28 is “Operation timeout. The specified time-out period was reached according to the conditions.”
So error 28 notify you that something is wrong on the senders side.
Posted: Tuesday 10 November 2020 15:13
by Number8
Thanks waaren, this is very valuable information
Posted: Tuesday 10 November 2020 16:01
by Number8
Let me get back on this cURL error 28. I understand the error is triggered by the sender, that is dzVEnts itself, in other words, by Domoticz itself. I'm wondering what can I do about that. How can it be tackled? The code is pretty straightforward
dz.openURL({
url = ipxURL,
callback = 'IPX800v3'
ipxURL is a private IP (LAN)
It is trigerred by the timer every minute. It fails a few times a day. What could be the root cause of the failure?
Current dz version is 2020.2 12485
Thank you
Posted: Tuesday 10 November 2020 18:52
by waaren
Number8 wrote: Tuesday 10 November 2020 16:01
Just guessing but it could be a hickup in your LAN or router or a very busy system.
Posted: Tuesday 10 November 2020 19:59
by Number8
very busy system
You mean the gear on which Domoticz is installed?
Everything is wired 1Gb/s, so taking account what is expected on the LAN, I can't expect any bottleneck. Hardware is NUC Intel, i5 6260 with 8GB of memory
Does this error mean that the TCP/IP can't even leave the interface?
Posted: Tuesday 10 November 2020 21:13
by waaren
Number8 wrote: Tuesday 10 November 2020 19:59
The messages tells you that curl (program or library) did not receive anything back within the default time. So no response from the target nor any error message.
Re: item.statusCode = 28? [Solved]
Posted: Tuesday 10 November 2020 21:33
by Number8
All right, this is very clear, thanks again
