Dimmer function
Posted: Sunday 08 November 2020 17:35
by sschouten
i have a ikea dimmer, connectd with zigbee to domoticz,
now i want to dim a ligth in domoticz, i cant find out how.
kind regards
Re: Dimmer function
Posted: Sunday 22 November 2020 21:53
by Wous
Same issue here. I've found several solutions, which can't compete the functionality of the hue bridge for example.
1st. Domoticz recognize the dimmer and gives the tradfi a selector switch. For each button you can give a json command. But for a dimmer, you want a relative dimlevel changed from the current position.
2nd. I've found a script which uses the lasting time of holding the button and uses that time for setting a dimlevel. Nice, but still not answering my need.
3rd. I've found a script for the hue dimmer switch https://domoticz.com/forum/viewtopic.php?f=59&t=33589. Because I haven't got a good interaction between Zigbee2Mqtt and the dimmer switch I haven't been able to evaluate this script.
Finally I am doubting using Domoticz to manage my Zigbee devices....
Re: Dimmer function
Posted: Tuesday 24 November 2020 20:10
I have no Ikea dimmer but a aqara switch with single click, double click, long click and 4 click function.
I switch a dimmable bulb with a long click by first getting the current dimlevel with dz.devices(id).level and then add 25 percent.
A double click always goes to dimlevel 25%
a 4-click always goes to 100%
See my dzVents script below.
   on = { devices = { 102 }},  -- Switch
   execute = function(dz, device )
        EKDimlevel = 0
        if dz.devices(102).state == 'Click' then -- 1 Click
            dz.devices(93).toggleSwitch()    -- Zigate Lamp
        if dz.devices(102).state == 'Double Click' then -- 2 Click
            dz.devices(93).dimTo(25)     -- Zigate Lamp
        if dz.devices(102).state == 'Long Click' then -- Long Click
            EKDimlevel = dz.devices(93).level
            dz.devices(93).dimTo(EKDimlevel+25)     -- Zigate Lamp
        if dz.devices(102).state == '4 Click' then -- 4 Click
            dz.devices(93).dimTo(100)    -- Zigate Lamp
Re: Dimmer function
Posted: Tuesday 24 November 2020 20:32
by klaasvaak
I created the following script for Hue selector switch, could be updated to ikea dimmer.
I'm an amateur in coding, so can be improved probably
		devices = {
			503 --Hue selector switch
        --States selector switch:
        --  off-press
        --  off-press-double
        --  off-press-triple
        --  off-hold
        --  off-hold-release
        --  down-press
        --  down-press-double
        --  down-press-triple
        --  down-hold
        --  down-hold-release
        --  up-press
        --  up-press-double
        --  up-press-triple
        --  up-hold
        --  up-hold-release
        --  on-press
        --  on-press-double
        --  on-press-triple
        --  on-hold
        --  on-hold-release
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Philips switch',
		     -- variables change settings
		     knopid = 503 -- id of the selector switch IMPORTANT! Also change @devices
		     lampl = 'keukengroep' -- lamp you want to control
		     delta = 33 -- percentage to increase / decrease lamp brightness
		     min = 1 -- minimal brightness
		     max = 100 -- maximum brightness
		     -- end vairables
		     lampdim = domoticz.devices(lampl).level
              if domoticz.devices(knopid).state == 'on-press' then
                     -- turn light on last state
                     domoticz.devices(lampl).switchOn()
              elseif domoticz.devices(knopid).state == 'up-press' then
                     -- turn light on to last state if off or increase brightness with delta
                     if domoticz.devices(lampl).state == 'Off'
                        then domoticz.devices(lampl).switchOn()
                        else domoticz.devices(lampl).dimTo(domoticz.devices(lampl).level + delta)
              elseif domoticz.devices(knopid).state == 'up-hold' or domoticz.devices(knopid).state == 'up-press-double' then
                     -- turn light on to max brightness
                     domoticz.devices(lampl).dimTo(max)
              elseif domoticz.devices(knopid).state == 'down-press' then
                     -- turn on to minimal if off or decrease brightness with delta
                     lampdim = lampdim - delta
                     if lampdim < min then
                        lampdim = min
                     domoticz.devices(lampl).dimTo(lampdim)
		      elseif domoticz.devices(knopid).state == 'down-hold' or domoticz.devices(knopid).state == 'down-press-double' then
                     -- decrease brightness to minimal
                     domoticz.devices(lampl).dimTo(min)
		      elseif domoticz.devices(knopid).state == 'off-press' or domoticz.devices(knopid).state == 'off-hold' then
                     -- turn of light
                     domoticz.devices(lampl).dimTo(0)
