Change lamp color before switching on
Posted: Saturday 07 November 2020 22:00
I'm a newby to dzvents and have a problem with my Innr RGBW lamp. I made a small test script in which the lamp is activated by a switch. After I switch it on, the lightcolor should be green, after a couple of seconds it should be red. The switch returns automatically to its Off-status and triggers a switchOff(). Problem is that the next time I push the switch the lamp gives a red flash before changing to green. I tried to change the color to green before the lamp switches off - that did not work. I also tried to change the color to black (RGB 000000) as in the code snippet but that didn't work either. Does anyone have a clue?
Peter
Peter
devices = {
'Schakelaar - Aqara 1'
local Lamp = domoticz.devices('Lamp - Innr 1')
if (device.state == 'B1') then
Lamp.setColorBrightness(25,25,0,0,0,0,3,0)
Lamp.setColorBrightness(25,0,0,0,0,0,3,0).afterSec(2)
if (device.state == 'Off') then
Lamp.setColorBrightness(0,0,0,0,0,0,3,0)
Lamp.switchOff().afterSec(1)
