Zigate on a remote domoticz
Posted: Tuesday 03 November 2020 0:30
by pascal3111
I'm using 2 domoticz server on raspberry, and i'm sharing some devices between the slave and the master.
I added a PIZIgate on the slave and I'm using the Zigate pluggin on domoticz, the installation is working correctly on the slave (all zigbee devices are seen) but I don't see the devices on the master. All others device on the slave are seen correctly on the master, only devices connected through the zigate are not visible. Do you you have a idea on how to correct that ? Or at least how to debug. ?
I see nothing anormal on the logs (both master & slave)
Re: Zigate on a remote domoticz
Posted: Tuesday 03 November 2020 7:35
by pipiche
You might report that to a domoticz subject as it is more related to the master/slave setup.
I wonder if master/slave is supported with python plugin like zigate plugin
Posted: Monday 16 November 2020 14:10
by HenkHavelaar
pascal3111, did you find a solution for this problem? I'm encountering the same problem, all sensors exept the Zigate sensors visible on the master.
Posted: Friday 20 November 2020 0:02
Looks like an old but unsolved domoticz python plugin issue https://github.com/domoticz/domoticz/issues/2642
