Installing domoticz on Freenas
Posted: Thursday 22 October 2020 18:58
by iguaan
Have anyone successfully installed/built latest domoticz 2020 to Freenas or Freebsd 11.3?
Maybe some tips what's different from previous domoticz installs.
Re: Installing domoticz on Freenas
Posted: Thursday 22 October 2020 21:42
by FireWizard
Posted: Wednesday 02 December 2020 21:54
by iguaan
FireWizard wrote:Hi,
See the WIKI: https://www.domoticz.com/wiki/FreeNAS
And also at iXsystems: https://www.truenas.com/community/threa ... ail.61030/
These are outdated guides.
They won't work for domoticz v2020.
They are missing dependencies, even if i install them, the build will fail at the end. It was at about 98, 99%
Sent from my MI 9 using Tapatalk
Posted: Thursday 03 December 2020 19:33
by FireWizard
Hi, @iguaan.
Sorry, for that. I do not run Domoticz in a TrueNAS (FreeNAS) jail, so it has not been tested.
I assume, you have also seen this Wiki.
https://www.domoticz.com/wiki/FreeBSD
I didn't test it either. But you can try, I think you need a FreeBSD package, so that you can simple install it with:
pkg install Domoticz
[Edit] Seems to be there: https://bugs.freebsd.org/bugzilla/show_ ... ?id=245007
I tried it, but it did not run.
Posted: Thursday 03 December 2020 21:31
by iguaan
Well gave it another try today and it worked like a charm:
* iocage create -n "domoticz" -r 11.3-RELEASE ip4_addr="your_interface_name|your_ip_address/24" defaultrouter="your_gateway" vnet="off" allow_raw_sockets="1" boot="on"
* iocage exec domoticz
* pkg update && pkg upgrade //although pkg was for freebsd 11.4 (running kernel: 1103000)
* pkg install domoticz
* cd /usr/local/etc/rc.d
* ee domoticz
edit-> : ${domoticz_enable:=YES}
test-> * ./domoticz
open url-> your_ip_address:8080
v2020.2
Guess the pi3 is going back to drawer as a backup device.
Posted: Thursday 03 December 2020 22:34
by FireWizard
Hi @iguaan
I will give it another try tomorrow, but I do not think it will replace my Raspberry Pi, as the Pi is at a complete different place in my house as my TrueNAS (formely FreeNAS) server and it also controls theP1 smart meter and RFXCom.
I keep you informed.
Posted: Friday 04 December 2020 14:52
by FireWizard
Hi @iguaan
I can confirm that I have Domoticz running in TrueNAS (formerly FreeNAS) 12 jail.
Actually I had it already successfully installed yesterday, however I did not start it correctly.
Like you said it was easy, but I did it in a somewhat different way.
Step 1.
Create the jail in the TrueNAS Gui. I called it Domoticz
Step 2.
Go to the Shell. You will be greeted by:
FreeBSD 12.2-RC3 7c4ec6ff02c(HEAD) TRUENAS
Welcome to FreeBSD!
Release Notes, Errata: https://www.FreeBSD.org/releases/
Security Advisories: https://www.FreeBSD.org/security/
FreeBSD Handbook: https://www.FreeBSD.org/handbook/
FreeBSD FAQ: https://www.FreeBSD.org/faq/
Questions List: https://lists.FreeBSD.org/mailman/listi ... questions/
FreeBSD Forums: https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with: pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed: freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages: man man
FreeBSD directory layout: man hier
Edit /etc/motd to change this login announcement.
Step 3
In the shell run the following commands.
pkg update
You will see:
root@domoticz:~ # pkg update
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]:
Answer: y
Bootstrapping pkg from pkg+http://pkg.FreeBSD.org/FreeBSD:11:amd64/quarterly, please wait...
Verifying signature with trusted certificate pkg.freebsd.org.2013102301... done
[domoticz] Installing pkg-1.15.10...
[domoticz] Extracting pkg-1.15.10: 100%
Updating FreeBSD repository catalogue...
[domoticz] Fetching meta.conf: 100% 163 B 0.2kB/s 00:01
[domoticz] Fetching packagesite.txz: 100% 6 MiB 6.3MB/s 00:01
Processing entries: 100%
FreeBSD repository update completed. 30622 packages processed.
All repositories are up to date.
pkg upgrade
This will probably end with "Your packages are up to date".
You will see that several new packages will be installed:
The following 19 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
boost-libs: 1.72.0_2
c-ares: 1.16.1
ca_root_nss: 3.58
curl: 7.72.0
domoticz: 2020.2_1
e2fsprogs-libuuid: 1.45.6
gettext-runtime: 0.21
icu: 67.1,1
indexinfo: 0.3.1
jsoncpp: 1.9.4
libedit: 3.1.20191231,1
libffi: 3.3_1
libnghttp2: 1.41.0
lua53: 5.3.5_3
minizip: 1.2.11
mosquitto: 1.6.7
python37: 3.7.9
readline: 8.0.4
sqlite3: 3.33.0,1
readline: 8.0.4
sqlite3: 3.33.0,1
Number of packages to be installed: 19
Install the packages
Step 4
Go to:
cd /etc
and edit rc.conf
ee rc.conf
And add the line:
domoticz_enable="YES"
Step 5
Issue the command:
cd /usr/local/etc/rc.d/domoticz start
(If you issue the command without start, you will get all other options.)
and go to your browser: http://<Your IP address>:8080
Screenshot_TrueNAS Domoticz.png (29.53 KiB) Viewed 1661 times
The first item, I configured were the "Motherboard Sensors".
Only one is available and that is Memory Usage with a negative value of -1%.
It gives also an error on the https port. But that is not so difficult to solve.
Screenshot_TrueNAS error.png (75.85 KiB) Viewed 1661 times
Also it does not give you the version number (except 2020.2), but I assume it is the most recent.
See: https://freebsd.pkgs.org/13/freebsd-arm ... 1.txz.html and
https://www.freshports.org/www/domoticz
Posted: Friday 04 December 2020 15:50
by FireWizard
To solve the problem Error: Webserver (SSL) follow the procedure as described in the Wiki.
See: https://www.domoticz.com/wiki/FreeBSD
Add to the file /etc/rc.conf beside the line
also the lines
domoticz_user="root"
domoticz_group="wheel"
Command:
cd /etc
ee rc.conf
