Dallas DS18B20 temp sensor(s) into Domoticz
Posted: Tuesday 20 October 2020 12:44
#!/bin/bash
INFO="Orange/Raspberry PI Dallas DS18B20 temp sensor(s), get value(s), and send to Domoticz every 5 minutes"
# Created by ILoveIoT 2019
# For console use : /root/scripts/gpio/dallas.temp.reading.sh
# For background use : /root/scripts/gpio/dallas.temp.reading.sh &
# Set in /boot/armbianEnv.txt
# dtoverlay=w1-gpio
# overlays=w1-gpio
# GPIO1 is used in this example for reading the Dallas DS18B20
# Use : gpio readall
# | Physical 12 | V1 | Mode IN | Name GPIO.1 | wPi 1 | BCM 110 |
# Uncomment/remove lines if you not using 4 Dallas device's
# Set the Domoticz server & port
SERVERIP="192.168.8.189"
SERVERPORT="8080"
# Set the Domoticz IDX for you're dummy temp device, check device's inside Domoticz for you're IDX
# Dallas Sensor at the breadboard high
DALLAS1IDX="88"
# Dallas Sensor kitchen low
DALLAS2IDX="35"
# Dallas Boiler sensor
DALLAS3IDX="87"
# Dallas shower sensor
DALLAS4IDX="36"
DALLAS5IDX="283"
# Use : ls /sys/bus/w1/devices/
# For getting the id for the device's, if you see none, something is wrong, (check /boot/armbianEnv.txt, dtoverlay=w1-gpio, overlays=w1-gpio)
DALLAS1="28-7187391e64ff"
DALLAS2="28-000004b4abc3"
DALLAS3="28-0315902d93ff"
DALLAS4="28-000004b413dc"
# Dallas accu sensor
DALLAS5="28-03159062bcff"
# Time for repeated sensor reading, in seconds
SLEEPTIME="120"
#SLEEPTIME="60"
# Use : dmesg | grep w1
# You should get a output like below, if get get abnormal readings to low/high check the cables of resistor (4.7-10k)
#[ 6.220359] w1_master_driver w1_bus_master1: Attaching one wire slave 28.dac81d1e64ff crc da
#[ 753.961177] w1_master_driver w1_bus_master1: Attaching one wire slave 28.6483391e64ff crc 45
#[ 2908.310134] w1_master_driver w1_bus_master1: Attaching one wire slave 28.7187391e64ff crc dc
#################################### BEGIN SCRIPT ##################################################
# Going into the loop, so you will have to run it once
while true; do
# Get the sensor temp value
SENSORTEMP1=`cat /sys/bus/w1/devices/$DALLAS1/w1_slave | sed -n 's/^.*\(t=[^ ]*\).*/\1/p' | sed 's/t=//' | awk '{x=$1}END{print(x/1000)}'`
SENSORTEMP2=`cat /sys/bus/w1/devices/$DALLAS2/w1_slave | sed -n 's/^.*\(t=[^ ]*\).*/\1/p' | sed 's/t=//' | awk '{x=$1}END{print(x/1000)}'`
SENSORTEMP3=`cat /sys/bus/w1/devices/$DALLAS3/w1_slave | sed -n 's/^.*\(t=[^ ]*\).*/\1/p' | sed 's/t=//' | awk '{x=$1}END{print(x/1000)}'`
SENSORTEMP4=`cat /sys/bus/w1/devices/$DALLAS4/w1_slave | sed -n 's/^.*\(t=[^ ]*\).*/\1/p' | sed 's/t=//' | awk '{x=$1}END{print(x/1000)}'`
SENSORTEMP5=`cat /sys/bus/w1/devices/$DALLAS5/w1_slave | sed -n 's/^.*\(t=[^ ]*\).*/\1/p' | sed 's/t=//' | awk '{x=$1}END{print(x/1000)}'`
# Just for debugging, you can comment these lines out if it works
#LS=`ls /sys/bus/w1/devices/ | grep 28`
#DMESG=`dmesg | grep w1`
#clear
#echo "$INFO"
#echo ""
#echo "Output off command dmesg | grep w1"
#echo "$DMESG"
#echo ""
#echo "Output off command /sys/bus/w1/devices/ | grep 28"
#echo "$LS"
#echo ""
#echo "Sensor ID = $DALLAS1 IDX = $DALLAS1IDX Temp = $SENSORTEMP1 C"
#echo "Sensor ID = $DALLAS2 IDX = $DALLAS2IDX Temp = $SENSORTEMP2 C"
#echo "Sensor ID = $DALLAS3 IDX = $DALLAS3IDX Temp = $SENSORTEMP3 C"
#echo "Sensor ID = $DALLAS4 IDX = $DALLAS4IDX Temp = $SENSORTEMP4 C"
#echo "Sensor ID = $DALLAS5 IDX = $DALLAS5IDX Temp = $SENSORTEMP5 C"
#echo ""
#echo ""
#current_date_time="`date +%H:%M:%S`";
#echo "$0 @ $current_date_time"
# Send the value to the Domoticz server, dont send if its 0 or more then 99 or less then -40, maybe you get false readings
if (( $(awk 'BEGIN {print ("'$SENSORTEMP1'" > "0")}') && $(awk 'BEGIN {print ("'$SENSORTEMP1'" < "99")}') )); then
curl -i -s "http://$SERVERIP:$SERVERPORT/json.htm?type=command¶m=udevice&idx=$DALLAS1IDX&nvalue=0&svalue=$SENSORTEMP1" >> /dev/null 2>&1
if (( $(awk 'BEGIN {print ("'$SENSORTEMP1'" < 0)}') && $(awk 'BEGIN {print ("'$SENSORTEMP1'" < -40)}') )); then
fi
fi
if (( $(awk 'BEGIN {print ("'$SENSORTEMP2'" > "0")}') && $(awk 'BEGIN {print ("'$SENSORTEMP2'" < "99")}') )); then
curl -i -s "http://$SERVERIP:$SERVERPORT/json.htm?type=command¶m=udevice&idx=$DALLAS2IDX&nvalue=0&svalue=$SENSORTEMP2" >> /dev/null 2>&1
if (( $(awk 'BEGIN {print ("'$SENSORTEMP2'" < 0)}') && $(awk 'BEGIN {print ("'$SENSORTEMP2'" < -40)}') )); then
fi
fi
if (( $(awk 'BEGIN {print ("'$SENSORTEMP3'" > "0")}') && $(awk 'BEGIN {print ("'$SENSORTEMP3'" < "99")}') )); then
curl -i -s "http://$SERVERIP:$SERVERPORT/json.htm?type=command¶m=udevice&idx=$DALLAS3IDX&nvalue=0&svalue=$SENSORTEMP3" >> /dev/null 2>&1
if (( $(awk 'BEGIN {print ("'$SENSORTEMP3'" < 0)}') && $(awk 'BEGIN {print ("'$SENSORTEMP3'" < -40)}') )); then
fi
fi
if (( $(awk 'BEGIN {print ("'$SENSORTEMP4'" > "0")}') && $(awk 'BEGIN {print ("'$SENSORTEMP4'" < "99")}') )); then
curl -i -s "http://$SERVERIP:$SERVERPORT/json.htm?type=command¶m=udevice&idx=$DALLAS4IDX&nvalue=0&svalue=$SENSORTEMP4" >> /dev/null 2>&1
if (( $(awk 'BEGIN {print ("'$SENSORTEMP4'" < 0)}') && $(awk 'BEGIN {print ("'$SENSORTEMP4'" < -40)}') )); then
fi
fi
if (( $(awk 'BEGIN {print ("'$SENSORTEMP5'" > "0")}') && $(awk 'BEGIN {print ("'$SENSORTEMP5'" < "99")}') )); then
curl -i -s "http://$SERVERIP:$SERVERPORT/json.htm?type=command¶m=udevice&idx=$DALLAS5IDX&nvalue=0&svalue=$SENSORTEMP5" >> /dev/null 2>&1
if (( $(awk 'BEGIN {print ("'$SENSORTEMP5'" < 0)}') && $(awk 'BEGIN {print ("'$SENSORTEMP5'" < -40)}') )); then
fi
fi
# sleep for 5 minutes, en then restart the process
# sleep 300
sleep $SLEEPTIME
done
##_EOF_##
