No device for each (3) phase Ampere with P1 Smart Meter (connected to Soconia T211 3 phase - Belgium)
giton
Post by giton »
Hello, I'm running Domoticz
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Information from my P1 Smart Meter contains the following 3 Ampere values but adding the Hardware to domoticz doesn't create any devices linked to them.
In my previous post viewtopic.php?t=33601 I got the following feedback:
Ampere values in the P1 Smart meter are rounded to A (and not mA) and are therefore not accurate enough to be considered as reliable values.
Therefore they are not included in Domoticz.
Otherwise, now, the P1 Meter get mA and not anymore rounder to A values.
As data are accurate, would it be possible to have them integrated as devices in Domoticz ?
root@raspberrypi:/home/pi/domoticz/scripts/dzVents/scripts# cat /dev/ttyUSB0
/FLU5\253769484_A
0-0:96.1.4(50214)
0-0:96.1.1(3153414733313030303733363338)
0-0:1.0.0(201019211500S)
1-0:1.8.1(000537.247*kWh)
1-0:1.8.2(000850.899*kWh)
1-0:2.8.1(000998.165*kWh)
1-0:2.8.2(000366.470*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(02.305*kW)
1-0:2.7.0(00.000*kW)
1-0:32.7.0(227.1*V)
1-0:52.7.0(228.6*V)
1-0:72.7.0(225.4*V)
1-0:31.7.0(003.58*A)
1-0:51.7.0(004.85*A)
1-0:71.7.0(003.93*A)
0-0:96.3.10(1)
0-0:17.0.0(999.9*kW)
1-0:31.4.0(999*A)
0-0:96.13.0()
!6F6E
Saunders
Re: No device for each (3) phase Ampere with P1 Smart Meter (connected to Soconia T211 3 phase - Belgium)
Post by Saunders »
Technical Specification For 3 Phase 4 Wire Whole-Current Smart Meters with authorities, unless specified separately elsewhere in this specification. S No. Base Current (Ib) – 10 Amps. of connect/ disconnect commands as per functional need of the available route in case of failure of any communication device.
PupilPath
