Dzvents Timer combine with dummy switch?  [Solved]
Larsoss
Post by Larsoss »
I would like to know if it is possible to switch the timer script on a dummy via Dzvents.
By this I mean that I have a dummy that shows the seasons. Autumn, Winter, etc ..
Now my script switches to a time window between 6:50 AM and 8:00 PM, but it always does. But I can also choose that for example
Dummy = Autumn, then switch between 7am & 9pm
Dummy = Winter, then switch between 08:00 & 20:00
Or is this not possible?
This is the script I currently use for switching the lamps.
return
    on =
        timer =
            "every 3 minutes on mon, tue, wed, thu, fri, sat, sun between 06:50 and 20:00",
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Auto verlichting ON',
    execute = function(dz)
        local lowerLux          = 11                            -- Onder welke niveau moet het script starten.
        local upperLux          = 45                            -- Boven de waarde gaan de lampen automatisch uit.
        local currentLux        = dz.devices(46).lux            --lux sensor
        local woonkamerlampen   = dz.groups("Woonkamer")        --Groep schakelaar Woonkamer.
        local tuin              = dz.groups("Tuin")             --Groep schakelaar Tuin.
        local phoneLarsOn       = dz.devices(150).state == 'On' --Dummy Telefoon Lars
        local phoneDesireeOn    = dz.devices(151).state == 'On' --Dummy Telefoon Dees
        if ( currentLux < lowerLux ) and ( phoneLarsOn or phoneDesireeOn ) then
            woonkamerlampen.switchOn().checkFirst()
            tuin.switchOn().checkFirst()
        elseif currentLux > upperLux then
            woonkamerlampen.switchOff().checkFirst()
            tuin.switchOff().checkFirst()
Because I had seen something where I suspect that it is possible.
return
    on =
        timer =
            'at sunset',
            'at ' .. Sleep,
        customEvents =
            retrigger,
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
Re: Dzvents Timer combine with dummy switch?
Larsoss wrote: Monday 19 October 2020 13:13 I would like to know if it is possible to switch the timer script on a dummy via Dzvents.
Although this can be done by creating a function in the active = section , it quite complicate the script and there is no real advantage compared to a simpler solution.
Have a look at below script
return
    on =
        timer =
            "every 3 minutes on mon, tue, wed, thu, fri, sat, sun between 06:50 and 22:00",
            -- "every 3 minutes between 06:50 and 22:00",  -- this is the same ( only 7 days in a week :-) )
    logging =
        local season = {}
        season.name = dz.devices('Seizoen').levelName
        season.Spring = 'at 07:00-21:00'
        season.Summer = 'at 07:00-22:00'
        season.Autumn = 'at 07:00-21:00'
        season.Winter = 'at 07:00-20:00'
        if dz.time.matchesRule(season[season.name]) then
            dz.log('No action needed (outside set time window)', dz.LOG_DEBUG)
Larsoss
Post by Larsoss »
So he's still watching between 6:50 AM / 10:00 PM, but won't switch between 7:00 AM / 9:00 PM because it's now fall?
That's how I read it correctly, right?
Re: Dzvents Timer combine with dummy switch?  [Solved]
Larsoss wrote: Monday 19 October 2020 23:26 So he's still watching between 6:50 AM / 10:00 PM, but won't switch between 7:00 AM / 9:00 PM because it's now fall?
No. In this example the script will be triggered every 3 minutes between 06:50 and 22:00 but in the script body you set the time per season that it will actually evaluate the lux and phones and act upon it.
So now (autumn) this example script will only do something between 07:00 and 21:00. During winter it will only do something between 07:00 and 20:00 etc.
Off course you can set the this time-window to anything you want / need. The on = timer section determines when the script start. The time-windows in the body determine when it can do something.
