Page 1 of 2
Timer script to turn off/on device
Posted: Saturday 17 October 2020 10:22
by gschmidt
I want to create a dzvents script that only turnes off a switch beween a time frame (02:00 - 06:30) and also If all smartphones are offline for 20 minutes (away) outside the time frame. I have installed iDetect plug-in, which also creates an on/off switch iDetect-home if all devices are online.
IF time is 02:00, turn off switch, and stays off even if iDetect-home switch is ON between 02:00-06:00
ELSEIF iDetect-home switch is off for 20 minutes, turn off switch
IF time is 06:30 and/or iDetect-home switch is on, turn on Switch.
Does anyone has an example script?
Re: Timer script to turn off/on device
Posted: Saturday 17 October 2020 11:29
by waaren
gschmidt wrote: Saturday 17 October 2020 10:22 IF time is 02:00, turn off switch, and stays off even if iDetect-home switch is ON between 02:00-06:00
Something like this?
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
            ['iDetect-home'] =
                'at 06:00-02:00',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'Time/Phones controlled switch',
    execute = function(dz, item)
        local switch = dz.device('switch') -- change to name of switch
        local iDetect = dz.device('iDetect-home')
        if dz.time.matchesRule('at 02:00-06:00') then
           switch.switchOff.checkFirst()
        elseif iDetect.state == 'Off' then
           switch.switchOff.afterMin(20)
        elseif iDetect.state == 'On' then
            switch.cancelQueuedCommands()
            if dz.time.matchesRule('at 06:30-01:59') then
                switch.switchOn().checkFirst()
Posted: Saturday 17 October 2020 13:49
by gschmidt
waaren wrote: Saturday 17 October 2020 11:29
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
            ['iDetect-home'] =
                'at 06:00-02:00',
    logging =
        local switch = dz.devices('switch') -- change to name of switch
        local iDetect = dz.devices('iDetect-home')
Wow,that is quick, thanx!
I guess that 6:00 Must be 0.6:30?
I did not understand how to set up the timer, just add the start and end times and the code below does the trick?:
dz.time.matchesRule('at 02:00-06:30')
Posted: Saturday 17 October 2020 14:31
by waaren
gschmidt wrote: Saturday 17 October 2020 13:49 I guess that 6:00 Must be 06:30?
No; according to you description is should be 06:00 but you can change it to whatever you like.
the at 02:00 and at 06:30 will trigger the script only at those moments.
The ['iDetect-home'] = { 'at 06:00-02:00', }, will trigger the script if the iDetect-home is switched between 06:00 and 02:00 (next day)
btw. noticed that I forgot the at on some places in my original post. Corrected it there now.
Posted: Saturday 17 October 2020 15:19
by gschmidt
waaren wrote: Saturday 17 October 2020 14:31
You are right I mistyped it in my description it should be 06:30...
I have changed it and also added the 'at ' at those places thanx!
Posted: Saturday 17 October 2020 15:45
by gschmidt
One more thing, this switch is turning on/off an electrical cat fence.
What happens if I turn off the switch manually (for maintenance), will this script turn it back on?
Posted: Saturday 17 October 2020 19:34
by waaren
gschmidt wrote: Saturday 17 October 2020 15:45 One more thing, this switch is turning on/off an electrical cat fence.
Yes. If the switch iDetect is updated to On between 6:00 and 2:00 (next day)
Posted: Sunday 18 October 2020 9:18
by gschmidt
waaren wrote: Saturday 17 October 2020 19:34
Well I have tested this and the script is not even triggered if I turn off the switch manually, the iDetect-home switch state was already On. Or is the script only triggered if the iDetect switch went from off to on or on to off?
Posted: Sunday 18 October 2020 15:14
by waaren
gschmidt wrote: Sunday 18 October 2020 9:18 Well I have tested this and the script is not even triggered if I turn off the switch manually, the iDetect-home switch state was already On. Or is the script only triggered if the iDetect switch went from off to on or on to off?
I also tested it and the script is triggered (and produced and error that I corrected below. If the script is not triggered at all, something else is causing it.
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
            ['iDetect-home'] =
                'at 06:00-02:00',
    logging =
Posted: Wednesday 21 October 2020 7:21
by gschmidt
waaren wrote: Sunday 18 October 2020 15:14
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
            ['iDetect-home'] =
                'at 06:00-02:00',
    logging =
Hi waaren,
The script was triggered last night and it produced an error, probably the same:
2020-10-21 02:00:00.395 Error: dzVents: Error: (3.0.11) Time/Phones controlled switch: An error occurred when calling event handler Electric_Fence_On_Off
2020-10-21 02:00:00.395 Error: dzVents: Error: (3.0.11) Time/Phones controlled switch: ...ipts/dzVents/generated_scripts/Electric_Fence_On_Off.lua:29: attempt to call a nil value (field 'device')
What part did you modify, because I can’t find the difference? Where is item used in the script as in function(dz, item)?
This is my current script:
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
            ['iDetect-Anyone'] =
                'at 06:30-02:00',
    logging =
        local switch = dz.device('Stopcontacten') -- change to name of switch
        local iDetect = dz.device('iDetect-Anyone')
        if dz.time.matchesRule('at 02:00-06:30') then
        dz.notify(switch.name,'Cat fence (' .. switch.name .. ') is turned: '.. switch.state ..'!', dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
Posted: Wednesday 21 October 2020 8:09
by waaren
gschmidt wrote: Wednesday 21 October 2020 7:21 The script was triggered last night and it produced an error, probably the same:
The correction was already in my previous post.
Change
to
local switch = dz.devices('Stopcontacten') -- change to name of switch
local iDetect = dz.devices('iDetect-Anyone')
Posted: Wednesday 21 October 2020 10:58
by gschmidt
Ah....devices instead of device....thanx, will try tonight
Posted: Thursday 22 October 2020 18:55
by gschmidt
waaren wrote: Wednesday 21 October 2020 8:09
Change
to
I tested it but found another error:
           switch.switchOff.checkFirst() β€” should be switch.switchOff().checkFirst()
           switch.switchOff.afterMin(20) β€” should be switch.switchOff().afterMin(20)
What kind of function is: switch.cancelQueuedCommands()?
Posted: Thursday 22 October 2020 19:20
by waaren
gschmidt wrote: Thursday 22 October 2020 18:55 I tested it but found another error:
πŸ‘Good catch
From the dzVents wiki
cancelQueuedCommands(): Function. Cancels queued commands. E.g. you switch on a device after 10 minutes: myDevice.switchOn().afterMin(10). Within those 10 minutes you can cancel that command by calling: myDevice.cancelQueuedCommands().
Posted: Friday 23 October 2020 17:29
by gschmidt
waaren wrote: Thursday 22 October 2020 19:20
πŸ‘Good catch
Hi waaren,
I am testing the script, something is not working correct.
Case 1: "Stopcontacten" is turned OFF at 02:00 which is correct, but also OFF at 06:30 ?? it should be turned ON at 06:30
Case 2: with the "iDetect-Anyone" switch the following happens:
1. After "iDetect-Anyone" is OFF, "Stopcontacten" is turned ON.... I also instantly get a telegram message that "Stopcontacten" is ON.....but also after 20m an ON message??? While "Stopcontacten" should be turned OFF.
2. When "iDetect-Anyone" is ON, "Stopcontacten" is turned ON....only one telegram message
This is the LOG for Case 2:
2020-10-23 17:36:19.155 Status: dzVents: Info: Handling events for: "iDetect-Anyone", value: "Off"
2020-10-23 17:36:19.155 Status: dzVents: Info: Time/Phones controlled switch: ------ Start internal script: Electric_Fence_On_Off: Device: "iDetect-Anyone (iDetect)", Index: 198
2020-10-23 17:36:19.156 Status: dzVents: Debug: Time/Phones controlled switch: Processing device-adapter for Stopcontacten: Switch device adapter
2020-10-23 17:36:19.157 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: Off
2020-10-23 17:36:19.157 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: Off AFTER 1200 SECONDS
2020-10-23 17:36:19.157 Status: dzVents: Debug: Time/Phones controlled switch: Cat fence (Stopcontacten) is turned: On!
2020-10-23 17:36:19.157 Status: dzVents: Info: Time/Phones controlled switch: ------ Finished Electric_Fence_On_Off
2020-10-23 17:36:19.158 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-23 17:36:19.172 Status: Notification: Stopcontacten
2020-10-23 17:42:05.006 Status: dzVents: Info: Handling events for: "iDetect-Anyone", value: "On"
2020-10-23 17:42:05.007 Status: dzVents: Info: Time/Phones controlled switch: ------ Start internal script: Electric_Fence_On_Off: Device: "iDetect-Anyone (iDetect)", Index: 198
2020-10-23 17:42:05.008 Status: dzVents: Debug: Time/Phones controlled switch: Processing device-adapter for Stopcontacten: Switch device adapter
2020-10-23 17:42:05.008 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: On
2020-10-23 17:42:05.008 Status: dzVents: Debug: Time/Phones controlled switch: Cat fence (Stopcontacten) is turned: On!
2020-10-23 17:42:05.008 Status: dzVents: Info: Time/Phones controlled switch: ------ Finished Electric_Fence_On_Off
2020-10-23 17:42:05.009 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-23 17:42:05.027 Status: Notification: Stopcontacten
This is my Current script:
--Script to turn off the cat electric fence (Stopcontacten) between 02:00-06:30 or if nobody is at home
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
                'at 06:30-02:00',
    logging =
    execute = function(dz)
        dz.log('Cat fence (' .. switch.name .. ') is turned: '.. switch.state ..'!', dz.LOG_INFO)
Posted: Friday 23 October 2020 20:19
by waaren
gschmidt wrote: Friday 23 October 2020 17:29 I am testing the script, something is not working correct.
Below modified script should solve Case 1 issue but not yet the unexpected notifications. It's not completely clear to me in which cases you want to receive a notification.
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
                'at 06:30-02:00',
    logging =
        if dz.time.matchesRule('at 02:00-06:29') then
		   return
Posted: Saturday 24 October 2020 9:05
by gschmidt
waaren wrote: Friday 23 October 2020 20:19 It's not completely clear to me in which cases you want to receive a notification.
Thanx, I will try tonight!
Regarding notifications:
dz & telegram notifications every ON and OFF.
In case of the iDetect-Anyone OFF after 20min, only notify OFF after 20m
But if iDetect-Home is ON again within those 20m, no notification is needed
Posted: Saturday 24 October 2020 10:21
by waaren
gschmidt wrote: Saturday 24 October 2020 9:05 Regarding notifications:
Like this?
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
                'at 06:30-02:00',
            'Stopcontacten',
    logging =
        local function notify(targetState)
            local msg = 'Cat fence (' .. switch.name .. ') has been switched to ' .. targetState ..'!'
            dz.notify(switch.name,msg, dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
            dz.log(msg, dz.LOG_INFO)
        dz.log(switch.name .. ' state: ' .. switch.state , dz.LOG_DEBUG)
        dz.log(iDetect.name .. ' state: ' .. iDetect.state , dz.LOG_DEBUG)
        if item == switch then
            notify(switch.state)
        elseif dz.time.matchesRule('at 02:00-06:29') then
            if switch.state ~= 'Off' then
                switch.switchOff().silent()
                notify('Off')
        elseif iDetect.state == 'Off' and switch.state ~= 'Off' then
            if dz.time.matchesRule('at 06:30-01:59') and switch.state ~= 'On' then
                switch.switchOn().silent()
                notify('On')
Posted: Saturday 24 October 2020 11:46
by gschmidt
waaren wrote: Saturday 24 October 2020 10:21
Like this?
return
    on =
        timer =
            'at 02:00',
            'at 06:30',
        devices =
                'at 06:30-02:00',
            'Stopcontacten',
    logging =
                notify('Off')
                notify('On')
Hi waaren,
Tested your script by turning off wifi of all 3 phones...so iDetect-Anyone is OFF now.
20min has not been passed yet. This is the log:
2020-10-24 11:13:48.453 Status: dzVents: Info: Handling events for: "iDetect-Anyone", value: "Off"
2020-10-24 11:13:48.453 Status: dzVents: Info: Time/Phones controlled switch: ------ Start internal script: Electric_Fence_On_Off: Device: "iDetect-Anyone (iDetect)", Index: 198
2020-10-24 11:13:48.454 Status: dzVents: Debug: Time/Phones controlled switch: Processing device-adapter for Stopcontacten: Switch device adapter
2020-10-24 11:13:48.454 Status: dzVents: Debug: Time/Phones controlled switch: Stopcontacten state: On
2020-10-24 11:13:48.454 Status: dzVents: Debug: Time/Phones controlled switch: iDetect-Anyone state: Off
2020-10-24 11:13:48.455 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: Off
2020-10-24 11:13:48.455 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: Off AFTER 1200 SECONDS
2020-10-24 11:13:48.455 Status: dzVents: Info: Time/Phones controlled switch: ------ Finished Electric_Fence_On_Off
2020-10-24 11:13:48.457 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
dz LOG produces "Stopcontacten state: On"....which is correct because it should be turned OFF after 20min
Telegram: no notification yet, which is correct because it should be send after 20min.
b.t.w. I also got a dz notification in the LOG which I don't recognize?:
2020-10-24 11:18:20.760 Status: ::ffff:192.168.1.1 -> handle abandoned timeout (status=6)
this is a message from my main router...I always open domoticz in the browser with a safe hpps connection (duckdns)
Does that procduce this message because each command in dz passes the WAN connection?
OK after 20min the script turns "Stopcontacten state: OFF", but no Telegram message is send
2020-10-24 11:33:48.723 Status: dzVents: Info: Handling events for: "Stopcontacten", value: "Off"
2020-10-24 11:33:48.724 Status: dzVents: Info: Time/Phones controlled switch: ------ Start internal script: Electric_Fence_On_Off: Device: "Stopcontacten (Zigbee2MQTT)", Index: 374
2020-10-24 11:33:48.725 Status: dzVents: Debug: Time/Phones controlled switch: Processing device-adapter for iDetect-Anyone: Switch device adapter
2020-10-24 11:33:48.725 Status: dzVents: Debug: Time/Phones controlled switch: Stopcontacten state: Off
2020-10-24 11:33:48.725 Status: dzVents: Debug: Time/Phones controlled switch: iDetect-Anyone state: Off
2020-10-24 11:33:48.725 Status: dzVents: Info: Time/Phones controlled switch: ------ Finished Electric_Fence_On_Off
Then I turned on the Wifi of the phones and iDetect-Anyone state went: ON. Both dz and telegram produce a Message.
However dz notifies: Stopcontacten state: Off, shoudn't that be ON?
2020-10-24 11:36:51.676 Status: dzVents: Info: Handling events for: "iDetect-Anyone", value: "On"
2020-10-24 11:36:51.676 Status: dzVents: Info: Time/Phones controlled switch: ------ Start internal script: Electric_Fence_On_Off: Device: "iDetect-Anyone (iDetect)", Index: 198
2020-10-24 11:36:51.677 Status: dzVents: Debug: Time/Phones controlled switch: Processing device-adapter for Stopcontacten: Switch device adapter
2020-10-24 11:36:51.677 Status: dzVents: Debug: Time/Phones controlled switch: Stopcontacten state: Off
2020-10-24 11:36:51.677 Status: dzVents: Debug: Time/Phones controlled switch: iDetect-Anyone state: On
2020-10-24 11:36:51.678 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: On
2020-10-24 11:36:51.678 Status: dzVents: Debug: Time/Phones controlled switch: Constructed timed-command: On NOTRIGGER
2020-10-24 11:36:51.678 Status: dzVents: Info: Time/Phones controlled switch: Cat fence (Stopcontacten) has been switched to On!
2020-10-24 11:36:51.678 Status: dzVents: Info: Time/Phones controlled switch: ------ Finished Electric_Fence_On_Off
2020-10-24 11:36:51.681 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-24 11:36:51.705 Status: Notification: Stopcontacten
2020-10-24 11:36:52.147 Notification sent (telegram) => Success
Posted: Saturday 24 October 2020 12:03
by waaren
gschmidt wrote: Saturday 24 October 2020 11:46 Then I turned on the Wifi of the phones and iDetect-Anyone state went: ON. Both dz and telegram produce a Message.
can you try again after changing
to
If still not OK then please continue via PM.
