Wrecked my RPi 3B+ boot is looping now.
Posted: Thursday 15 October 2020 21:07
by McMelloW
Dear forummers,
It is not Domoticz, but more the Raspberry Pi that is used to run domoticz.
I hope there is a Raspberry Guru out there to help me. I did the following commands
sudo apt-get update
sudo apt-get full-upgrade
sudo rpi-update
sudo reboot now
The rpi did not boot but appears to be in a boot lopping, starting over and over again.
It is a headless Pi so I connected a screen and keyboard. The last thing I see is polkit.servce just below the RPi logo and the flash a blue-screen and starting again.
Flashed a new SD-card with the Raspberry Pi Imager, used this card to boot but no change. Is the Pi really wrecked? Who can help?
Re: Wrecked my RPi 3B+ boot is looping now.
Posted: Thursday 15 October 2020 21:20
by FireWizard
Posted: Thursday 15 October 2020 21:56
by McMelloW
Yes, I did this, but it did not solve my problem. But also with a fresh clean Buster the RPi is in boot looping.
I can try this, but I have to copy the image back on another SD card. Not available yet.
Posted: Thursday 15 October 2020 23:29
by Tukker
Huh?
Did you check
the raspberrypi forum as well?
And how is it when you prepare an SD card with NOOBS?
Posted: Thursday 15 October 2020 23:56
by McMelloW
HvdW wrote: Thursday 15 October 2020 23:29
Huh?
Did you check
Yes I did, I am searching since monday all over internet.
When I put this card in an older RPi 2B it boots like a charm.
So what is wrong with the card? Does a 3B+ uses other files then a 2B to boot? Is this an fstab problem?
Can do that, what is the advantage of NOOBS (Never used it before.)
Posted: Friday 16 October 2020 15:05
by FireWizard
Hi, @McMellow,
Perhaps you can look to this thread as well:
https://www.raspberrypi.org/forums/view ... 28&t=58151@
You can check the 3V3 voltage. If this has gone, I think you have to contact your supplier.
Posted: Friday 16 October 2020 17:16
by McMelloW
Hi folks, thanks for your support so far.
@HvdW I did the init=/bin/sh in the cmdline.txt There is no problems with the fstab file. No change, still a looping boot.
Haven't created a NOOBs sd-card yet. Have no spare cards left.
@FireWizard Checked the 3V3 value. This is OK. Studying at the
https://www.raspberrypi.org/forums/view ... 28&t=58151 topic, this takes some more time.
Still wondering, I understand there is no flash memory at all on the RPi. How can it have boot problems with a brand new installed Buster?
[SOLVED] Wrecked my RPi 3B+ boot is looping now.
Posted: Saturday 17 October 2020 11:51
by McMelloW
Finaly!! It boots (headles) again, altough it is not very stable. Fortunately, I ordered a new RPi 3B+ so my Domomticz is up and running again.
After the looking at the fstab file and studying the
https://www.raspberrypi.org/forums/view ... 28&t=58151 topic, I realized the 5V power supply is an issue. Attaching a keyboard and a mouse might consume to much power to get the RPi booting OK.
It is a more delicate board then I thought at first.
Everybody thanks again for all your effort and pointing me to right direction
