The script works, but it shouldn't. Why?
Posted: Wednesday 14 October 2020 21:18
by besix
Hello, I have a script that should execute in time.
Domoticz last beta.
Why is it working now?
It's October
The date and time in domoticz is up to date
	    timer = {'at 21:17 on mon,wed,fri,sun on 20/04-28/09'},
	    devices = {'Przekaźnik 1'}
	   logging =	{
					--	level   =   domoticz.LOG_ERROR,
						level   =   domoticz.LOG_DEBUG,
						marker  =   "Time and relay"
	execute = function(dz, item)
       	local relay = dz.devices("Przekaźnik 1")
		local relay2 = dz.devices("Przekaźnik 2")
		if (item.isTimer) then
		   relay.switchOn()
		elseif relay.state == "On" then
			relay2.switchOn().afterSec(4)
The full script is here
	    timer = {'at 3:00 on mon,wed,fri,sun on 20/04-28/09'},
	     devices = {'Nawadnianie'}
	   logging =	{
						-- level   =   domoticz.LOG_DEBUG,
						marker  =   "Nawadnianie ogrodu"
       	local selector = dz.devices("Nawadnianie")
        local zone1 = dz.devices("Podlew Róże")
		local zone2 = dz.devices("Podlew Front")
		local zone3 = dz.devices("Podlew Trawnik1")
		local zone4 = dz.devices("Podlew Trawnik2")
		local zone5 = dz.devices("Podlew Trawnik3")
		local zone6 = dz.devices("Podlew Trawnik4")
		local zones = { zone1, zone2, zone3, zone4,zone5, zone6 }
		dz.log(selector.name .. ' Jest w trybie ' .. selector.state, dz.LOG_DEBUG)
		for _, zone in ipairs(zones) do
			zone.cancelQueuedCommands() -- usuwa stare zaplanowane  start / stop
			zone.switchOff().checkFirst()
		   selector.switchSelector(10)
		elseif selector.state == "Auto" then
			zone1.switchOn().forMin(40)
			zone2.switchOn().afterMin(10).forMin(30)
			zone3.switchOn().afterMin(40).forMin(30)
			zone4.switchOn().afterMin(70).forMin(30)
			zone5.switchOn().afterMin(100).forMin(30)
			zone6.switchOn().afterMin(130).forMin(30)
			selector.switchSelector(0).afterMin(161)
		elseif selector.state == "Stop" then
			zone1.switchOff()
		    zone2.switchOff()
		    zone3.switchOff()
		    zone4.switchOff()
		    zone5.switchOff()
		    zone6.switchOff()
Re: The script works, but it shouldn't. Why?
Posted: Wednesday 14 October 2020 22:45
by waaren
besix wrote: Wednesday 14 October 2020 21:18 Hello, I have a script that should execute in time.
Why is it working now? It's October
This script can be triggered by either the timer trigger or the devices trigger.
Given it is October it will now only execute when triggered by the device.
Posted: Wednesday 14 October 2020 22:55
by besix
Thank you for your response.
Yes I know the trigger is time or relay, but two relays are OFF and at 21:17 the script is doing relay1 On. Then, of course, relay 2 On after 4sec
log
2020-10-14 21:02:00.379 Status: dzVents: Info: Nawadnianie ogrodu: ------ Start internal script: Script #1:, trigger: "at 21:02 on mon,wed,fri,sun on 20/04-28/09"
2020-10-14 21:02:00.398 Status: dzVents: Debug: Nawadnianie ogrodu: Processing device-adapter for Przekaźnik 1: Switch device adapter
2020-10-14 21:02:00.399 Status: dzVents: Debug: Nawadnianie ogrodu: Processing device-adapter for Przekaźnik 2: Switch device adapter
2020-10-14 21:02:00.399 Status: dzVents: Debug: Nawadnianie ogrodu: Constructed timed-command: On
2020-10-14 21:02:00.399 Status: dzVents: Info: Nawadnianie ogrodu: ------ Finished Script #1
2020-10-14 21:02:00.400 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-14 21:02:00.521 Status: dzVents: Info: Handling events for: "Przekaźnik 1", value: "On"
2020-10-14 21:02:00.521 Status: dzVents: Info: Nawadnianie ogrodu: ------ Start internal script: Script #1: Device: "Przekaźnik 1 (AFE)", Index: 18
2020-10-14 21:02:00.522 Status: dzVents: Debug: Nawadnianie ogrodu: Processing device-adapter for Przekaźnik 2: Switch device adapter
2020-10-14 21:02:00.522 Status: dzVents: Debug: Nawadnianie ogrodu: Constructed timed-command: On
2020-10-14 21:02:00.522 Status: dzVents: Debug: Nawadnianie ogrodu: Constructed timed-command: On AFTER 4 SECONDS
2020-10-14 21:02:00.522 Status: dzVents: Info: Nawadnianie ogrodu: ------ Finished Script #1
2020-10-14 21:02:00.523 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Posted: Thursday 15 October 2020 0:11
by waaren
besix wrote: Wednesday 14 October 2020 22:55 Yes I know the trigger is time or relay, but two relays are OFF and at 21:17 the script is doing relay1 On. Then, of course, relay 2 On after 4sec
Thx for reporting!
Seems indeed not working as expected. Have to check the code in Time.lua and the wiki to see what is wrong
[EDIT] the code in Time.lua does not handle timeRules with multiple on correct.
Can you please check after replacing line 527 of <domoticz dir>/dzVents/runtime/Time.lua from
		local dates = string.match(rule, 'on% ([0-9%*%/%,% %-]*)')
to
		local dates = rule:gsub('(on%s+[%a+])',''):match('on%s+([0-9%*%/%,% %-]*)') -- strip on ddd before matching rule
Re: The script works, but it shouldn't. Why?  [Solved]
Posted: Thursday 15 October 2020 8:56
by besix
Hello
After changing the line 527 the script works fine.
When I set September, it does not start. And it only works when relay is trigger
When there is a date October follows the date
Posted: Thursday 15 October 2020 9:10
by waaren
besix wrote: Thursday 15 October 2020 8:56 Hello
Thx for testing ! See my previous post (I shortened the test to one line again)
Posted: Thursday 15 October 2020 9:20
by besix
When I change it, will it be valid in the new beta domoticz?
EDIT
I did the 527 line change again and it works wrong again
log
2020-10-15 09:29:00.608 Status: dzVents: Info: Time and relay: ------ Start internal script: time + relay:, trigger: "at 09:29 on mon,wed, thu, fri,sun on 20/04-28/09"
2020-10-15 09:29:00.626 Status: dzVents: Debug: Time and relay: Processing device-adapter for Przekaźnik 1: Switch device adapter
2020-10-15 09:29:00.627 Status: dzVents: Debug: Time and relay: Processing device-adapter for Przekaźnik 2: Switch device adapter
2020-10-15 09:29:00.627 Status: dzVents: Info: Time and relay: Time = true
2020-10-15 09:29:00.628 Status: dzVents: Debug: Time and relay: Constructed timed-command: On
2020-10-15 09:29:00.628 Status: dzVents: Info: Time and relay: ------ Finished time + relay
2020-10-15 09:29:00.628 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-15 09:29:00.726 Status: dzVents: Info: Handling events for: "Przekaźnik 1", value: "On"
2020-10-15 09:29:00.727 Status: dzVents: Info: Time and relay: ------ Start internal script: time + relay: Device: "Przekaźnik 1 (AFE)", Index: 18
2020-10-15 09:29:00.728 Status: dzVents: Debug: Time and relay: Processing device-adapter for Przekaźnik 2: Switch device adapter
2020-10-15 09:29:00.728 Status: dzVents: Debug: Time and relay: Constructed timed-command: On
2020-10-15 09:29:00.728 Status: dzVents: Info: Time and relay: ------ Finished time + relay
2020-10-15 09:29:00.729 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
line 527
   function self.ruleIsOnDate(rule)
                local dates = rule:match('on%s+([0-9%*%/%,% %-]*)')
                if (isEmpty(dates)) then
                        return nil
Posted: Thursday 15 October 2020 9:28
by waaren
besix wrote: Thursday 15 October 2020 9:20 When I change it, will it be valid in the new beta domoticz?
Yes. I will merge this in a next beta but until then you can change the line yourself.
Posted: Thursday 15 October 2020 9:37
by besix
See the post above
Posted: Thursday 15 October 2020 9:56
by waaren
besix wrote: Thursday 15 October 2020 9:37 See the post above
Reverted my earlier simplification in the post so back to the previous 4 lines ... :(
Need to study these patterns a bit more..
[EDIT] found a one solution.
Posted: Thursday 15 October 2020 15:28
by besix
Your last solution works. Thank you
