PiZiGate not working
Posted: Saturday 10 October 2020 1:09
Got my PiZiGate in yesterday and installed it today in my Raspberry. Installed the plugin and had some issues figuring some of the settings out for the plugin for the PiZiGate (what port to use etc). I can not seem to get the hardware/plugin to work. Maybe i am missing steps or i am doing something wrong?
Below is the logging i get from my Domoticz setup. Serial port has been enabled with raspi-config as well.
Thanks in advance for the help!
2020-10-10 00:57:30.326 Status: (PiZigate) Started.
2020-10-10 00:57:33.637 Status: (PiZigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-10 00:57:33.639 Status: (PiZigate) Entering work loop.
2020-10-10 00:57:33.653 Status: (PiZigate) Zigate plugin stable-4.11.003 started
2020-10-10 00:57:33.653 Status: (PiZigate) Debug: 0
2020-10-10 00:57:33.654 Status: (PiZigate) load PluginConf
2020-10-10 00:57:33.665 Status: (PiZigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-06.json
2020-10-10 00:57:33.666 Status: (PiZigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 00:57:33.666 Status: (PiZigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 00:57:33.666 Status: (PiZigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-10 00:57:33.666 Status: (PiZigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-10 00:57:33.669 Status: (PiZigate) Switching Heartbeat to 5 s interval
2020-10-10 00:57:33.669 Status: (PiZigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-10 00:57:33.669 [GCC 8.3.0]
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzVersion: 2020.2
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzHash: b63341bc0
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzBuildTime: 2020-04-26 13:47:55
2020-10-10 00:57:33.671 Status: (PiZigate) Opening DomoticzDB in raw
2020-10-10 00:57:33.744 Status: (PiZigate) Plugin Database: DeviceList-6.txt
2020-10-10 00:57:33.786 Status: (PiZigate) DeviceConf loaded
2020-10-10 00:57:34.496 Status: (PiZigate) load ListOfDevice
2020-10-10 00:57:35.405 Status: (PiZigate) ==> Transport Mode: auto
2020-10-10 00:57:35.475 Status: (PiZigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2020-10-10 00:57:35.476 Status: (PiZigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
