Temperature limit 380
Tate
Post by Tate »
(release notes: Version 1.1680 (April 21th 2014) - Changed: Temperatures are now valid till 380 degrees)
what is a reason behind this temperature limit ?
And is it possible to easy override it somehow ?
I have a 1-wire MAX31850 with k-type thermocouple and now i can't use a whole range of the sensor.
( i guess that 380 degree is enough, but still...)
Limit doesn't come from MySensors, cause the gateway is happily forwarding values.
And a bit strange is that i can enter values over 380 via json to domoticz.
(/json.htm?type=command&param=udevice&idx=13&nvalue=0&svalue=500)
-Tate
