[Solved] Dots under floorplan in case multiple floorplans disappeared.
Posted: Tuesday 06 October 2020 16:58
Usually, in case of multiple Floor plans, you are able to switch to another Floor plan by clicking the dot under the Floor plan.
After a recent update only under the first Floor plan, the dots are visible. As soon as you click on one of the dots, you move to the selected Floor plan, but the dots have disappeared. So it is impossible to select another Floor plan.
You have to go to the tab on the top menu in order to go back to the first plan and then select another.
Currently running 2020.2 (build 12451)
Raspberry Pi 2
Browsers: Firefox, Waterfox and Chrome,
Has anyone seen the same behavior?
Raspberry Pi 2
