Execute Python script in dzvents
Posted: Thursday 01 October 2020 20:48
by jberinga
When trying to execute a Python script in dzvents:
        devices = { 'Test' },
    if
        domoticz.devices('Test').state == 'On'
    then
        domoticz.devices('Test').switchOff().afterSec(5)
        domoticz.utils.osExecute("script:///usr/bin/python /volume1/@appstore/domoticz/var/scripts/python/volumeset.py 031")
nothing is happening; it should set the volume to a certain level. There are no errors in the log.
When activating the script (script:///usr/bin/python /volume1/@appstore/domoticz/var/scripts/python/volumeset.py 031) in the On Action of the device, the volume is changed.
What am I doing wrong? :?
Re: Execute Python script in dzvents
Posted: Thursday 01 October 2020 21:28
by waaren
jberinga wrote: Thursday 01 October 2020 20:48 What am I doing wrong? :?
You don't need the script:// part when executing from a script.
Can you try with
    logging =
    	level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
    	marker = 'Python execution',
    if
    then
        domoticz.utils.osExecute("/usr/bin/python /volume1/@appstore/domoticz/var/scripts/python/volumeset.py 031")
        -- if standard execution does not work you could try with sudo
        -- domoticz.utils.osExecute("sudo /usr/bin/python /volume1/@appstore/domoticz/var/scripts/python/volumeset.py 031")
Re: Execute Python script in dzvents  [Solved]
Posted: Friday 02 October 2020 16:42
by jberinga
Thanks waaren!
That did it (domoticz.utils.osExecute("/usr/bin/python /volume1/@appstore/domoticz/var/scripts/python/volumeset.py 031"))
