LUA script to control heat pump optimizing power from photovoltaic!!
Posted: Thursday 01 October 2020 0:02
Controlling the heat pump optimizing power consumption, is not really easy, but it's possible!
I'm using a LUA script + a configuration LUA file for this purpose, for both heating and cooling, and it works very very well!
Cooling only when there is enough energy from the photovoltaic system (no energy from the electric grid).
Heating: it trys to regulate the heat pump power to reduce power consumption when there is no power production from photovoltaic (and rooms are almost in temperature), and increase heat pump power, fluid temperature and zone setpoints when there is an extra photovoltaic production (it's better to heat the house a little bit more than the setpoint today, if it's sunny, because tomorrow it can be cloudy).
I've explain something in the following page, where you can find the commands to download the two LUA scripts.
https://www.creasol.it/support/domotics ... otovoltaic
I hope this can be useful for you. Any suggestions are welcome!
