'On For x' doesn't work?!!
abdolhamednik
Domoticz version: 4.9700
Post by abdolhamednik »
hello everyone
i have problem with the command:
commandArray['deviceA'] = 'On For x' ... it doesn't work. deviceA maintains on for all times!
does anyone have seen this problem?
jvdz
Domoticz version: 4.107
Re: 'On For x' doesn't work?!!
Post by jvdz »
This should work fine and switch it on for 1 minute:
commandArray['deviceA ']='On FOR 1'
What type of switch is deviceA and what is the exact statement you use?
Jos
abdolhamednik wrote: Tuesday 29 September 2020 10:25 i have problem with the command:
This does happen if deviceA was already On.
I think it is safer to use
commandArray[#commandArray + 1] = { ['deviceA' ] = 'On' }
commandArray[#commandArray + 1] = { ['deviceA' ] = 'Off AFTER ' .. x }
abdolhamednik
thanks to waaren... it worked
thanks to jvdz. it is a light switch/on-off
