greenhouse circulating fan
Posted: Tuesday 29 September 2020 9:07
hello everyone
a circulating fan should work for 5 minutes and stop working for 15 minutes in a greenhouse, only when the exhaust fan is off for some time, i.e. 20 minutes. By the way, the code below is a "time" event, running every minutes
i don't understand why this simple code doesn't work. Can u plz help me
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
Smart = tonumber(uservariables['Smart'])
if Smart == 0 then --zero means smart system should be inactive
crtoggle = tonumber(uservariables['crtoggle']) --a parameter
if devicechanged['fan1'] == 'On' then
commandArray['circule1'] = 'Off'
elseif otherdevices['fan1'] == 'Off' then
if timedifference(otherdevices_lastupdate['fan1']) > 1200 then
if otherdevices['circule1'] == 'On' then
if crtoggle == 5 then
crtoggle = 0
crtoggle = crtoggle + 1
if crtoggle == 15 then
commandArray['circule1'] = 'On'
crtoggle = 0
commandArray['Variable:crtoggle'] = tostring(crtoggle)
