Window open -> stop heating
Posted: Monday 28 September 2020 23:02
by groovesurfer
I use different heating sensors (Eurotronic Spirit) and windows open/closed sensors.
Now I want the heating sensor to lower the temperature to 10 degrees when the window is opened. When the window is closed again, the temperature should return to the previous value.
I tried to do this with the following event:
This works, but the heating sensor continuously readjusts (every 30 seconds) loudly.
Is there any other way to do this?
My heating plan:
0am - 18 degrees
6am - 21 degrees
9pm - 18 gedrees
Re: Window open -> stop heating
Posted: Monday 28 September 2020 23:48
by waaren
groovesurfer wrote: Monday 28 September 2020 23:02
I would not know how to do this in Blockly (probably something with an additional uservariable)
but in dzVents it could look like below script.
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
return
on =
devices =
'Türe Terrasse',
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
marker = 'Heizung',
execute = function(dz, item)
local heizung = dz.devices('Heizung Wohnzimmer')
local function setSetPoint(dv, setPoint)
local function round(value)
return dz.utils.round(value, 1)
if round(dv.setPoint) ~= round(setPoint) then
dv.updateSetPoint(round(setPoint))
local function thermostat(dv)
local setPoint = 18
if dz.time.matchesRule('at 06:00-21:00') then
setPoint = 21
dz.log(item.name .. ' updated. State is now ' .. item.state,dz.LOG_DEBUG)
if item.state == 'Open' then
setSetPoint(heizung, 10)
thermostat(heizung)
Posted: Tuesday 29 September 2020 9:08
by groovesurfer
Thank you very much for your reply.
The script works, but when I open the door/window (the heating sensor goes to 10 degrees) an close it again, it goes to 18 degrees and not to 21.
What can I do?
Posted: Tuesday 29 September 2020 9:25
by waaren
groovesurfer wrote: Tuesday 29 September 2020 9:08
What can I do?
Please try again after changing the line
if dz.time.matchesRule('06:00-21:00') then
to
Posted: Tuesday 29 September 2020 9:45
by groovesurfer
Cool, that works. Thank you very much.
Posted: Tuesday 29 September 2020 22:22
by groovesurfer
Now it´s after 21:00 o´clock and the heating didn´t change the temperature to 18 degrees.
What can be the mistake?
Posted: Wednesday 30 September 2020 0:22
by waaren
groovesurfer wrote: Tuesday 29 September 2020 22:22
So far the script only reacted to a device event. This one should also control the thermostat time based.
return
on =
devices =
'Türe Terrasse',
timer =
'at 06:00',
'at 21:01',
logging =
marker = 'Heizung',
local setPoint = 18
setPoint = 21
if item.isTimer then
thermostat(heizung)
thermostat(heizung)
Posted: Wednesday 30 September 2020 9:49
by harrykausl
I have the same constellation with the Eurotonics and window-sensors. I did it in another way. When window is opended, I change the haeating mode to off, when window is closed, I turn it on again. It switches automatically to the last temperature. The time based temperatures are onyl handled in time-plans of the thermostat device. To switch the heater off or on, I have a dummy-switch. When turning this off or on, the eurotonics changes the mode. The advantage of this is, that I see automatically at this switch, if all works correct when window status changes. All is done with lua.
Posted: Wednesday 30 September 2020 14:12
by groovesurfer
Thank you for your posts.
@harry: can you tell me it how you have done it with lua? I never used lua before.
Posted: Wednesday 30 September 2020 17:17
by harrykausl
If you want to do it with lua, you should test a little bit with that environment. Then I can try to help you.
Posted: Wednesday 30 September 2020 17:23
by waaren
groovesurfer wrote: I never used lua before.
Yes you did
dzVents is 100% Lua
Posted: Wednesday 30 September 2020 17:42
by groovesurfer
ah ok
The script (waaren) works now perfect.
Thank you
