It goes from dark purple to bright yellow, then switches to white and brightens up untill full.
You need to put the white and collored light on the lowest setting and then off before using this script, because the lamp will turn on at its last postion.
Hope someone likes it. Will work on every linux system, not Domoticz only.
I tried it on group 1, would be happy if someone could test on other groups.
https://www.youtube.com/watch?v=dLhDJibXruk
Here you can see what it does....
#!/bin/bash
# This script comes with no warranty ...use at own risk
# Copyright (C) 2014 Peter H. Roubos
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; version 2 of the License.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# This script can be used as a wake me up script using a wifi RGBW led
# like AppLamp/LimitedLed/Mi-Light/IWY Color etc.
# I use it in Domoticz but should work on every linux system
# Version 0.1 15 sept 2014
# Change variables to your liking here
IP=192.168.1.38 # ip adress of your wifibox
PORT=8899 # port of your wifibox, normaly 8899
GROUP=1 # use 1,2,3,4 for the group you want
RUNTIME=6 # time that the script will go from begin to end (0 is about 2 minutes 6 about 10 minutes 15 about 30 minutes)
# NO CHANGES AFTER THIS LINE -NO CHANGES AFTER THIS LINE -NO CHANGES AFTER THIS LINE -NO CHANGES AFTER THIS LINE #
let GROUP=$GROUP*2
let LAMPCODE=67+$GROUP
let WHITECODE=195+$GROUP
let UIT=$AAN-1
let DIMMER=2
let COLOR=190
function verzend(){
echo -n -e $SENDCOM | nc -u -q 1 $IP $PORT
sleep $RUNTIME
##SEND ON Command
printf -v ONCOMMAND '%x' $LAMPCODE
SENDCOM="\x"$ONCOMMAND"\x00"
## Loop to change the colors and the brightness
while [ $DIMMER > 27 ]
do
## Send dimmer command
printf -v ONCOMMAND '%x' $DIMMER
SENDCOM="\x4E\x"$ONCOMMAND
verzend
## Send Again, it's udp, you never know
verzend
## Send Color command
printf -v ONCOMMAND '%x' $COLOR
SENDCOM="\xC0\x"$ONCOMMAND
verzend
COLOR=`expr $COLOR - 1`
verzend
if [ $DIMMER -eq 27 ]
then
break
fi
DIMMER=`expr $DIMMER + 1`
done
## Now we do the same, but with white and start with a bit of light already
DIMMER=5
do
verzend
verzend
printf -v ONCOMMAND '%x' $WHITECODE
SENDCOM="\x"$ONCOMMAND"\x00" #White
verzend
then
break
fi
done
