Kwikset Door Lock Issue
dpcreel
Post by dpcreel »
Any updates on the issue with the Command Class: Locked(Advanced) with Kwikset Door locks?
This is the error I continue to receive whenever the door is lock/unlocked through Domoticz or manually: 2020-09-21 21:44:06.431 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 45 (0x2d), CommandClass: DOOR LOCK, Label: Locked (Advanced), Instance: 1, Index: 1
My error logfile shows nothing but errors with this lock. Looks like Domoticz cannot handle the Locked(Advanced), OZW control panel displays the data fine. It's been awhile sine the problem was first Identified.
I am running Domoticz V2020.2 (build 12392) on a RPI with OZW Version: 1.6-1240-g01c8d001
After some research I found this: https://github.com/OpenZWave/open-zwave/issues/1992, which may explain things a little better OR
https://github.com/domoticz/domoticz/is ... -605625421
Please help as my error logfile gets filled quickly with these junk errors.
dpcreel
Re: Kwikset Door Lock Issue
Post by dpcreel »
Any update on this?
