Newbie - Internal & External Temp & Humidity over Wireless
Posted: Tuesday 22 September 2020 12:12
I'm a relative new comer to Domoticz and would like some advice.
Currently I have a Domoticz server running in Linux thats hosted as a virtual machine on a home server.
I have two Honeywell EvoHome central heating controllers attached and logging fine.
I have solid 2.4G & 5G WiFi across all our buildings.
I'm looking to add Temperature and Humidity sensors to all room as well an external sensor. Being a Yorkshireman married to a Scott I don't want to spend a fortune but will spend what it takes to get a stable and quality solution.
Can someone suggest a solution that based on AA or AAA rechargeable batteries that will only need changing one a year and ideally give some form of Low Battery warning via the Domoticz server so I can trigger a 'Swap the batteries' e-mail.
Small sensors with s local readout would be good but not essential.
I'm happy with an alternate wireless solution to the WLAN but I'll need to cover a 60m x 60m plot with four buildings on it.
I've spent quite a bit of time looking at the forum and the supported hardware lists but most of the time I ended up finding out the hardware is no longer available so I thought someone from the collective would hopefully stop me going round in circles.
Finally, I'm also looking for a discrete wind strength and direction sensor to add to the system.
Thank you in anticipation
Charles
Charles
