Page 1 of 2
Set Light to On based on motion detection between time
Posted: Monday 21 September 2020 16:44
by Xavier82
I searched the forum but couldn't find what I was looking for....
Could any one help me with a dzvents script to activate the light on our frontdoor when the camera with motion detection has detected motion between 00.00 hours and sunrise?
I have the next setup:
Camera connected to Domoticz but also to Synology Surveillance Station.
In Surveillance station I have setup an action rule based on url to Domoticz to IDX of Camera.
The action rule in Surveillance Station is triggered by motion of the camera.
But now I'm stuck...
So what should the script do?
It would be great of the light goes on when motion is detected between 00:00 hours and sunrise.
I hope somebody can help me with this.
Thanks in advance
Regards,
Xavier
Re: Set Light to On based on motion detection between time
Posted: Monday 21 September 2020 16:52
by waaren
Xavier82 wrote: Monday 21 September 2020 16:44
How does this call to domoticz looks like and what is it supposed to do?
Is the domoticz version number in your profile correct and if so is there a reason why you have not upgraded to a more recent stable release?
Posted: Monday 21 September 2020 19:40
by Xavier82
Hi Waaren,
updated my profile.
Version is 2020.2 stable.
The call from Surveillance station is an action based on a URL wich triggers the IDX of a switch in domoticz namen " Camera Motion Detection".
Normally this has as an action that when motion is detected I receive a notificaties in telegram with a snapshot of the camera.
Posted: Monday 21 September 2020 20:28
by waaren
Xavier82 wrote: Monday 21 September 2020 19:40
Hi Waaren,
updated my profile.
Can you try with this dzVents script?
return
on =
devices =
['Camera Motion Detection'] = { 'between 00:00 and sunrise' },
logging =
level = domoticz.LOG_DEBUG,
marker = 'Camera',
execute = function(dz, item)
local light = dz.devices('Name of your light')
local offDelay = 300
if item.active then -- state == 'On'
light.cancelQueuedCommands()
light.switchOn()
light.switchOff().afterSec(offDelay)
Posted: Monday 21 September 2020 23:26
by Xavier82
Thanks for the code but I get this error:
2020-09-21 23:25:09.101 Error: dzVents: Error: (3.0.2) error loading module 'Voordeur verlichting' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Voordeur verlichting.lua':
2020-09-21 23:25:09.101 ...ripts/dzVents/generated_scripts/Voordeur verlichting.lua:11: <eof> expected near '='
Posted: Monday 21 September 2020 23:32
by waaren
Xavier82 wrote: Monday 21 September 2020 23:26
There was an error in the script which is now corrected please try again but note that the script in its current form will only work after 00:00
Posted: Monday 21 September 2020 23:39
by Xavier82
waaren wrote: Monday 21 September 2020 23:32
Thanks, error is gone for now.
Will keep an eye on it
Posted: Tuesday 22 September 2020 8:06
by Xavier82
So I checked the logging this morning, but the light didn't go on. I had several motion detections (a cat walked by). I receive a notificaties in telegram on my Phone but it looks like the script hasn' t been triggered.
I have adjusted the name of the lamp in the script.
Any idea why not?
Posted: Tuesday 22 September 2020 9:41
by waaren
Xavier82 wrote:
Any idea why not?
Can you share the exact URL that activates the device with the telegram action?
Posted: Tuesday 22 September 2020 12:02
by Xavier82
waaren wrote: Tuesday 22 September 2020 9:41
Xavier82 wrote:
Any idea why not?
Sure, the URL in Synology Surveillance Station which is triggered on motion is:
http://<IP_ADRES_Domoticz>:<port domoticz>/json.htm?type=command¶m=switchlight&idx=26&switchcmd=On
Posted: Tuesday 22 September 2020 13:01
by waaren
Xavier82 wrote: Tuesday 22 September 2020 8:06
Any idea why not?
Please try again after changing cancelQueuedCommand to cancelQueuedCommands
Posted: Tuesday 22 September 2020 16:34
by Xavier82
Waaren,
I made the adjustment.
Will keep you posted about this.
Greetz,
Xavier
Posted: Tuesday 22 September 2020 19:05
by Melotron
Hi.
I've been trying to get a similar script running for myself for a few motion sensors.
I'am getting the following error :
2020-09-22 18:52:11.225 ...ticz/scripts/dzVents/generated_scripts/dz timer test.lua:4: '}' expected near '='
The script that I'am using are this:
return
on =
{ devices = { 118 = { 'between sunset and sunrise' }, }, },
execute = function(domoticz)
local myTextDevice = 82
if domoticz.devices(118).state == 'On' then
myTextDevice.updateText('Motion')
domoticz.devices(42).switchOn()
domoticz.devices(42).switchOff().afterSec(40)
end }
It would be wonderful to get a scrip like this working even for setting a warmer kelvin on the lamps after sunset too =)
//Magnus Svensson
Posted: Tuesday 22 September 2020 21:10
by waaren
Melotron wrote: Tuesday 22 September 2020 19:05
Hi.
Syntax to use is
return
on =
devices =
[118] = { 'between sunset and sunrise' },
Posted: Tuesday 22 September 2020 21:56
by Melotron
waaren wrote: Tuesday 22 September 2020 21:10
Hi.
Syntax to use is
return
on =
devices =
Thanks alot =)
Its finally working.
Are there any way to put the time at the devices like :
domoticz.devices(42).switchOn().at(between sunset and sunrise)
//Magnus Svensson
Posted: Wednesday 23 September 2020 0:15
by waaren
Melotron wrote: Tuesday 22 September 2020 21:56
Sorry but I don't understand what you try to achieve. switchOn() can be delayed until a moment in future but not between aaa and bbb.
Can you please explain ?
Posted: Wednesday 23 September 2020 6:51
by Melotron
I want to have a low Kelvin during daytime and a higher Kelvin after the sun goes down.
I can achieve that with 2 scripts, but I could shrink my scripts down by setting times when a specific lamp should be on in a script.
Posted: Wednesday 23 September 2020 9:04
by waaren
Melotron wrote: Wednesday 23 September 2020 6:51
Like this?
return
on =
timer =
'at sunset',
'at sunrise',
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
marker = 'lights at night',
execute = function(dz)
local light = dz.devices(42)
if dz.time.matchesRule('at sunrise') then
light.switchOff()
light.switchOn()
Posted: Wednesday 23 September 2020 9:12
by Xavier82
Waaren,
Tested the enhancement but no result.
For testing now I made a second actionrule in Synology Surveillance Station which is:
http://<IP_ADRES_Domoticz>:<port domoticz>/json.htm?type=command¶m=switchlight&idx=186&switchcmd=On
IDX 186 is the IDX of my frontdoor light which I want to activate.
When testing the light goes on indeed, but how can I be sure the light only goes on between the entered time and goes off after 300seconds?
This is the code for now:
return
on =
devices =
['Voordeurlamp'] = { 'between 00:00 and sunrise' },
logging =
marker = 'Camera',
local light = dz.devices('Voordeurlamp')
light.switchOn()
Posted: Wednesday 23 September 2020 9:21
by Xavier82
mmmzzz, when rethinking about this....
What actually should happen is that the lamp on the frontdoor goes on WHEN "Camera motion dection" between 00:00 and sunrise FOR 5 minutes.
In other words I would like to re-use already existing scripts in Surveillance Station and Domoticz.
The trigger of this script should be a switch (IDX 26) in Domoticz.
Can this be done?
