Zigbee2mqtt struggling with inputs PTVO unit and Nodered [SOLVED]
Posted: Sunday 20 September 2020 15:32
by Jan Jansen
I want to use a PTVO unit (based on a CC2530 + CC2591) with 2 inputs and 1 output. The configuration is as follows:
Board type: CC2530 + CC2591
Model ID: ptvo.switch
Location description: Schuur
Power saving mode (PSM): No
Output pins:
P13: Output 1, GPIO, Pull-down, Remember state
P12: Output 2, GPIO, Pull-down, Remember state
P16: Output 3, GPIO, Pull-down, Remember state
Input pins:
P03: Input 1, GPIO, Pull-down, Switch, Link to out 1
P02: Input 2, GPIO, Pull-down, Switch, Link to out 2
The unit was easy to paire using the python plugin zigbee2mqtt. The following devices have been created automatically (see attachment 1 bottom page)
The results of the testing are as follows:
Activation of a switch on input 1 of the PTVO unit gives no response in Domoticz (IDX 112)
Activation of a switch on input 2 of the PTVO unit does not give a response in Domoticz (IDX 113)
Activation of IDX 114 in the Domoticz web interface activates the corresponding output of the PTVO unit as desired.
Switching inputs 1 and 2 gives the following reactions in the Domoticz log.
 2020-09-20 15:22:04.251 (Zigbee bridge) MqttClient::ping
2020-09-20 15:22:04.553 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 85, 'state_l1': 'OFF', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:04.607 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 85, 'state_l1': 'OFF', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:04.610 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 85, 'state_l1': 'OFF', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:05.415 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 83, 'state_l1': 'OFF', 'state_l2': 'ON', 'state_l3': 'OFF'}
2020-09-20 15:22:07.533 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 80, 'state_l1': 'OFF', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:12.050 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 88, 'state_l1': 'ON', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:13.066 (Zigbee bridge) MQTT message: zigbee2mqtt/Schuur {'linkquality': 85, 'state_l1': 'OFF', 'state_l2': 'OFF', 'state_l3': 'OFF'}
2020-09-20 15:22:14.231 (Zigbee bridge) MqttClient::ping
The PTVO unit is working properly. I need some help linking the inputs of the unit to Domoticz.
I know I have to use NodeRed but I get stuck on the function node.
[{"id":"f67e81dd.a7aef","type":"tab","label":"Schuur","disabled":false,"info":""},{"id":"68a4ac18.550654","type":"mqtt in","z":"f67e81dd.a7aef","name":"PTVO schuur","topic":"zigbee2mqtt/Schuur","qos":"2","datatype":"auto","broker":"4595d216.dc87fc","x":160,"y":180,"wires":[["d4661a0c.c08fd8"]]},{"id":"d4661a0c.c08fd8","type":"json","z":"f67e81dd.a7aef","name":"","property":"payload","action":"","pretty":false,"x":390,"y":180,"wires":[["73382182.355cc","e1b3a50c.4adfc8"]]},{"id":"73382182.355cc","type":"function","z":"f67e81dd.a7aef","name":"","func":"var msg1 ={}; // Deurcontact IDX:117\nvar msg2 ={}; // PIR IDX:118\n\ndelete msg.payload.linkquality;\ndelete msg.payload.state_l3;\n\n\nreturn [[msg1,msg2]];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":180,"wires":[["57907cc1.d8a824"]]},{"id":"57907cc1.d8a824","type":"mqtt out","z":"f67e81dd.a7aef","name":"Domoticz In","topic":"domoticz/in","qos":"","retain":"","broker":"9220d244.9bc46","x":830,"y":180,"wires":[]},{"id":"e1b3a50c.4adfc8","type":"debug","z":"f67e81dd.a7aef","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":580,"y":260,"wires":[]},{"id":"4595d216.dc87fc","type":"mqtt-broker","z":"","name":"Zigbee","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"domoticz/bridge/state","birthQos":"0","birthPayload":"online","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"9220d244.9bc46","type":"mqtt-broker","z":"","name":"MQTT_Server","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Output DEBUG PTVO schuur (see attachment 3)
Output DEBUG function node (see attechment 2)
IDX 118 switches as desired, IDX 117 does not.
Thanks in advance!
Schermafbeelding 2020-09-20 145439.png (60.25 KiB) Viewed 5702 times
