Looking for best practice: Virtual lux
najtram
Domoticz version: v4.9700
Post by najtram »
I’m looking forward to find a new way to be able to have a virtual Lux sensor.
These two do NOT seem to work any more:
1 https://www.domoticz.com/wiki/Real-time ... Lux_sensor..
2 https://ehoco.nl/domoticz-weerstation/
Could you help me find a working way?
Kind regards
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
zicht
Domoticz version: 2023.1+
Re: Looking for best practice: Virtual lux
Post by zicht »
Virtual lux is still possible to make with a dummy device !
But you are struggling with WU as it is not available the way it was ( for free).
There are several data suppliers but all not reliable (at least for me all give odd values) The only relaiable data is paid or shared (as far as i could find,)
What i did is making a custom sensor based on my solar pannels power output.
OK It is not lux, but pretty much gives an indication that is usable for the same purpose.
The other solution would be to BUY a lux sensor, they are pretty cheap. Recently i got a outdoor motion sensor with temp and lux included.
kiddigital
Post by kiddigital »
Look at OpenWeatherMap and find out if there is good PWS nearby that reports Lux values that work for your situation.
You just need a free API key to get it up and running in Domoticz.
najtram wrote:I’m looking forward to find a new way to be able to have a virtual Lux sensor.
I use the average production of my Solar panels over the last 15 minutes to control some of my lightsImage
Works for me.
najtram
Post by najtram »
Thanks, for the ideas.
I'm modifying my blocky events now to match production of my Enphase system. What are your value's for twilight? I'm thinking of 120watt...
And could some of you point me out in an "avarage production script" direction?
Kind regards.
ZigBee → ConBee II
LAN → Enphase Envoy
najtram wrote: Sunday 13 September 2020 14:13 I'm modifying my blocky events now to match production of my Enphase system. What are your value's for twilight? I'm thinking of 120watt...
That more or less depends on the amount of solar panels and how they are placed. Just start with a value and adjust when needed.
My solar panel production is measured by a youless energymonitor. I use below dzVents script to "translate" the average energy produced to a virtual lux sensor.
avgerageYouless.lua
return
    on =
        timer =
            'at daytime every 1 minutes',
            '5 minutes after sunset',
    data =
        powerYield =
            history = true,
            maxItems = 15,
    logging =
        level = domoticz.LOG_ERROR,
        marker = 'averageYouless',
    execute = function(dz)
        local virtualLux = dz.devices(964)
        local youless = dz.devices(133)
        if dz.time.matchesRule('at daytime') then
            -- add new data
            dz.data.powerYield.add(youless.powerYield)
            -- average 'lux' to lux device
            virtualLux.updateLux(dz.data.powerYield.avg())
        else -- after sunset
            virtualLux.updateLux(0)
            dz.data.powerYield.reset()
EdwinK
Post by EdwinK »
Unfortunately I can't find any stations nearby that has LUx value;s :(
