trying to install 2020.2 version, kepp getting 404
Posted: Wednesday 09 September 2020 21:21
by red59
helllo,
i'm trying to get domoticz 2020.2 working in my docker env, build is fine, but when laucnhing it i get 404 error.
seems not having anything in domoticz.log (will check again and post).
here command used to launch :
ENTRYPOINT ["/opt/domoticz/domoticz", "-dbase", "/config/domoticz.db", "-log", "/config/domoticz.log", "-sslwww", "8443"]
CMD ["-www", "8080"]
i have also tried with blank database, but same thing.
Thansk for your help
Re: trying to install 2020.2 version, kepp getting 404
Posted: Thursday 10 September 2020 19:04
by red59
here logs :-(
2020-09-10 19:03:28.875  Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-09-10 19:03:28.875  Status: Build Hash: aad65002e, Date: 2020-04-26 15:49:25
2020-09-10 19:03:28.876  Status: Startup Path: /opt/domoticz/
2020-09-10 19:03:28.944  BuildManifest: Created directory /opt/domoticz/plugins/
2020-09-10 19:03:28.999  Status: PluginSystem: Started, Python version '3.7.3'.
2020-09-10 19:03:29.004  Active notification Subsystems: fcm, http (2/13)
2020-09-10 19:03:29.006  Status: WebServer(HTTP) started on address: 0.0.0.0 with port 8080
2020-09-10 19:03:29.009  Error: [web:443] missing SSL certificate chain file ./server_cert.pem!
2020-09-10 19:03:29.009  Error: [web:443] missing SSL certificate file ./server_cert.pem!
2020-09-10 19:03:29.009  Error: [web:443] missing SSL private key file ./server_cert.pem!
2020-09-10 19:03:29.009  Error: [web:443] missing SSL DH parameters file ./server_cert.pem!
2020-09-10 19:03:29.010  Error: [web:443] missing SSL certificate chain file ./server_cert.pem!
2020-09-10 19:03:29.010  Error: [web:443] missing SSL certificate file ./server_cert.pem!
2020-09-10 19:03:29.011  Error: [web:443] missing SSL private key file ./server_cert.pem!
2020-09-10 19:03:29.011  Error: [web:443] missing SSL DH parameters file ./server_cert.pem!
2020-09-10 19:03:29.012  Error: [web:443] missing SSL certificate chain file ./server_cert.pem!
2020-09-10 19:03:29.012  Error: [web:443] missing SSL certificate file ./server_cert.pem!
2020-09-10 19:03:29.012  Error: [web:443] missing SSL private key file ./server_cert.pem!
2020-09-10 19:03:29.012  Error: [web:443] missing SSL DH parameters file ./server_cert.pem!
2020-09-10 19:03:29.013  Status: WebServer(SSL) started on address: 0.0.0.0 with port 443
2020-09-10 19:03:29.016  Starting shared server on: 0.0.0.0:6144
2020-09-10 19:03:29.016  Status: TCPServer: shared server started...
2020-09-10 19:03:29.018  Status: RxQueue: queue worker started...
2020-09-10 19:03:31.018  Status: NotificationSystem: thread started...
2020-09-10 19:03:31.019  Status: EventSystem: reset all events...
2020-09-10 19:03:31.019  Status: EventSystem: reset all device statuses...
2020-09-10 19:03:31.066  Status: Python EventSystem: Initalizing event module.
2020-09-10 19:03:31.066  Status: EventSystem: Started
2020-09-10 19:03:31.067  Status: EventSystem: Queue thread started...
2020-09-10 19:03:31.445  Status: PluginSystem: Entering work loop.
Posted: Thursday 10 September 2020 20:12
by jake
It seems to error on ssl certificate. You don't have them, but as far i know you don't need a secure connection either. http is sufficient within your own network. Can't you somehow skip the https with that port 443 stuff?
