Vulnerability and weak encryption ciphers
Posted: Thursday 03 September 2020 22:38
by WujcioPafcio
Hi All!
I just started my adventure with Domoticz.
I configured it, secured it and published it into the world.
Now I scanned the server for SSL security and Qualys Cloud Platform.
SSL Test reported below weak ciphers.
Additionally I have a questions:
  • Can we disable it?
  • What webservice using Domoticz or where is SSL configuration?
TLS_RSA_WITH_AES_128_CBC_SHA (0x2f)   WEAK
TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x33)   DH 2048 bits   FS   WEAK
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013)   ECDH secp521r1 (eq. 15360 bits RSA)   FS   WEAK
TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c)   WEAK
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (0x67)   DH 2048 bits   FS   WEAK
TLS_RSA_WITH_AES_128_GCM_SHA256 (0x9c)   WEAK
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027)   ECDH secp521r1 (eq. 15360 bits RSA)   FS   WEAK
TLS_RSA_WITH_AES_128_CCM (0xc09c)   WEAK
TLS_RSA_WITH_AES_128_CCM_8 (0xc0a0)   WEAK
TLS_RSA_WITH_AES_256_CBC_SHA (0x35)   WEAK
TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x39)   DH 2048 bits   FS   WEAK
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014)   ECDH secp521r1 (eq. 15360 bits RSA)   FS   WEAK
TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d)   WEAK
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (0x6b)   DH 2048 bits   FS   WEAK
TLS_RSA_WITH_AES_256_GCM_SHA384 (0x9d)   WEAK
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028)   ECDH secp521r1 (eq. 15360 bits RSA)   FS   WEAK
TLS_RSA_WITH_AES_256_CCM (0xc09d)   WEAK
TLS_RSA_WITH_AES_256_CCM_8 (0xc0a1)   WEAK
SSL scan reporting also lack of support for Forward Secrecy ( INFO1 , INFO2 )
Second think are reported vulnerabilities in Qualys scanner.
Here is reported one on Medium level (score 2/5)
  • HTTP Security Header Not Detected
THREAT:
This QID reports the absence of the following HTTP headers according to CWE-693: Protection Mechanism Failure:
X-Frame-Options: This HTTP response header improves the protection of web applications against clickjacking attacks. Clickjacking, also known as a "UI redress attack", allows an attacker to use multiple transparent or opaque layers to trick a targeted user into clicking on a button or link on another page when they were intending to click on the the top level page.
X-XSS-Protection: This HTTP header enables the browser built-in Cross-Site Scripting (XSS) filter to prevent cross-site scripting attacks. X-XSS-Protection: 0; disables this functionality.
X-Content-Type-Options: This HTTP header prevents attacks based on MIME-type mismatch. The only possible value is nosniff. If your server returns X-Content-Type-Options: nosniff in the response, the browser will refuse to load the styles and scripts in case they have an incorrect MIME-type.
Strict-Transport-Security: The HTTP Strict-Transport-Security response header (HSTS) is a security feature that lets a web site tell browsers that it should only be communicated with using HTTPS, instead of using HTTP.
QID Detection Logic:
This unauthenticated QID looks for the presence of the following HTTP responses:
Valid directives for X-Frame-Options are:
X-Frame-Options: DENY - The page cannot be displayed in a frame, regardless of the site attempting to do so.
X-Frame-Options: SAMEORIGIN - The page can only be displayed in a frame on the same origin as the page itself.
X-Frame-Options: ALLOW-FROM RESOURCE-URL - The page can only be displayed in a frame on the specified origin.
Valid directives for X-XSS-Protections are:
X-XSS-Protection: 1 - Enables XSS filtering (usually default in browsers). If a cross-site scripting attack is detected, the browser will sanitize the page (remove the unsafe parts).
X-XSS-Protection: 1; mode=block - Enables XSS filtering. Rather than sanitizing the page, the browser will prevent rendering of the page if an attack is detected.
X-XSS-Protection: 1; report=URI - Enables XSS filtering. If a cross-site scripting attack is detected, the browser will sanitize the page and report the violation. This uses the functionality of the CSP report-uri directive to send a report.
X-XSS-Protection: 0 disables this directive and hence is also treated as not detected.
A valid directive for X-Content-Type-Options: nosniff
A valid HSTS directive Strict-Transport-Security: max-age=<expire-time>; [; includeSubDomains][; preload]
NOTE: All report-only directives (where applicable) are considered invalid.
IMPACT:
Depending on the vulnerability being exploited, an unauthenticated remote attacker could conduct cross-site scripting, clickjacking or MIME-type sniffing attacks.
SOLUTION:
Note: To better debug the results of this QID, it is requested that customers execute commands to simulate the following functionality: curl -lkL --verbose.
CWE-693: Protection Mechanism Failure mentions the following - The product does not use or incorrectly uses a protection mechanism that provides sufficient defense against directed attacks against the product. A "missing" protection mechanism occurs when the application does not define any mechanism against a certain class of attack. An "insufficient" protection mechanism might provide some defenses - for example, against the most common attacks - but it does not protect against everything that is intended. Finally, an "ignored" mechanism occurs when a mechanism is available and in active use within the product, but the developer has not applied it in some code path.
Customers are advised to set proper X-Frame-Options, X-XSS-Protection, X-Content-Type-Options and Strict-Transport-Security HTTP response headers.
Depending on their server software, customers can set directives in their site configuration or Web.config files. Few examples are:
X-Frame-Options:
Apache: Header always append X-Frame-Options SAMEORIGIN
nginx: add_header X-Frame-Options SAMEORIGIN;
HAProxy: rspadd X-Frame-Options:\ SAMEORIGIN
IIS: <HTTPPROTOCOL><CUSTOMHEADERS><ADD NAME="X-Frame-Options" VALUE="SAMEORIGIN"></ADD></CUSTOMHEADERS></HTTPPROTOCOL>
X-XSS-Protection:
Apache: Header always set X-XSS-Protection "1; mode=block"
PHP: header("X-XSS-Protection: 1; mode=block");
Apache: Header always set X-Content-Type-Options: nosniff
HTTP Strict-Transport-Security:
Apache: Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains"
Nginx: add_header Strict-Transport-Security max-age=31536000;
Note: Network devices that include a HTTP/HTTPS console for administrative/management purposes often do not include all/some of the security headers. This is a known issue and it is recommend to contact the vendor for a solution.
COMPLIANCE:
Not Applicable
EXPLOITABILITY:
There is no exploitability information for this vulnerability.
ASSOCIATED MALWARE:
There is no malware information for this vulnerability.
RESULTS:
X-Frame-Options or Content-Security-Policy: frame-ancestors HTTP Headers missing on port 443.
GET / HTTP/1.1
Host: ip-236.212-91-26-0.dynamic.chello.pl
Connection: Keep-Alive
HTTP/1.1 200 OK
Last-Modified: Tue, 25 Aug 2020 21:27:44 GMT
Content-Length: 74155
Content-Type: text/html;charset=UTF-8
Access-Control-Allow-Origin: *
Keep-Alive: max=20, timeout=20
Strict-Transport-Security HTTP Header missing on port 443.
And two Potential Vulnerabilities on Serious level (score 3/5)
  • jQuery Prior to 3.5.0 Cross-Site Scripting Vulnerability
QID: 13770
Category: CGI
CVE ID: CVE-2020-11022
Vendor Reference Jquery
Bugtraq ID: -
Service Modified: 05/26/2020
User Modified: -
Edited: No
PCI Vuln: Yes
THREAT:
JQuery is prone to a cross-site-scripting vulnerability because it fails to sufficiently sanitize user-supplied input.
Affected Versions:
jQuery versions greater than or equal to 1.2 and before 3.5.0.
QID Detection Logic(Unauthenticated):
It checks for vulnerable versions of jQuery from default web page.
IMPACT:
An attacker may leverage this issue to execute arbitrary script code in the browser of an unsuspecting user in the context of the affected site.
SOLUTION:
Vendor has advised to Upgrade jquery to version 3.5.0
Patch:
Following are links for downloading patches to fix the vulnerabilities:
jQuery
COMPLIANCE:
Not Applicable
EXPLOITABILITY:
ASSOCIATED MALWARE:
RESULTS:
jQuery Version Prior to 3.5.0 Detected.jquery-ui.min.css" />
  • jQuery Cross-Site Scripting Vulnerability
QID: 13772
Category: CGI
CVE ID: CVE-2020-11023
Bugtraq ID: -
User Modified: -
Edited: No
PCI Vuln: Yes
THREAT:
Affected Versions:
jQuery versions greater than or equal to 1.0.3 and before 3.5.0.
IMPACT:
SOLUTION:
Patch:
jQuery
COMPLIANCE:
Not Applicable
EXPLOITABILITY:
ASSOCIATED MALWARE:
RESULTS:
Is jQuery going to be upgraded in next version of Domoticz?
Or I can upgrade it on my own without breaking anything?
Re: Vulnerability and weak encryption ciphers
Posted: Friday 04 September 2020 5:35
by ben53252642
Personally I access Domoticz via a VPN into my home network.
My setup is not security focused, I have Domoticz running as the root user so I would never consider making it directly accessible via the internet.
Even if it wasn't running as the root user, I still would not make it directly accessible via the internet.
Posted: Friday 04 September 2020 8:12
by WujcioPafcio
I prepared my Domoticz for Google Home Assistant and voice control.
Unfortunately, this functionality requires Internet access.
Posted: Friday 04 September 2020 9:28
by EddyG
If you want to expose your Domoticz to the outside world then use
1. Letsencrypt (free).
2. A totally random portnumber.
3. A random username.
4. A strong password for that user.
Then I think you are save.
Posted: Friday 04 September 2020 9:31
by freijn
WujcioPafcio wrote: Friday 04 September 2020 8:12 I prepared my Domoticz for Google Home Assistant and voice control.
only allow Google servers to acces your domoticz, block any other ipaddress.
Posted: Friday 04 September 2020 11:23
by WujcioPafcio
Maybe two simple questions?
  • is there any options to change manually in some config files of webservice SSH encryption methods?
  • Is jQuery going to be upgraded in next version of Domoticz or I can upgrade it on my own without breaking anything?
Posted: Friday 04 September 2020 13:49
by lost
So you seems concerned by security... and you widely open your system to google and accept an always on microphone inside your home???! :lol:
Posted: Friday 04 September 2020 13:52
by lost
freijn wrote: Friday 04 September 2020 9:31 only allow Google servers to acces your domoticz, block any other ipaddress.
No way IMO: They must be doing heavy load balancing between servers with many & always moving IP ranges that'll be difficult to know in advance.
Posted: Friday 04 September 2020 14:54
by WujcioPafcio
lost wrote: Friday 04 September 2020 13:49
Google is following us anyway, whether we want it or not. Android devices, Chrome browser...
Better Google than unknown Russians, so please be smart somewhere else ;)
Posted: Friday 04 September 2020 16:41
by Number8
ben53252642 wrote: Friday 04 September 2020 5:35 Personally I access Domoticz via a VPN into my home network.
I have the same approach.
Posted: Saturday 05 September 2020 9:15
by EddyG
WujcioPafcio wrote: Friday 04 September 2020 14:54
Just to be smart anyway.
Use an old Nokia 3210 and DuckDuckGo with a VPN then you no longer supplying Google with info.
I have my system totally open, as described, and never had any problems and keep my fingers crossed.
B.T.W. The links you mentioned won't scan my site because I do not use port 443. Go figure!
And believe me Google has interest in you, the Russians don't, and the Chinese might.
Posted: Monday 07 September 2020 9:29
by lost
WujcioPafcio wrote: Friday 04 September 2020 14:54 so please be smart somewhere else ;)
This is not really being "smart" to be able to make a difference between been followed by google trackers (with some mitigations still possible, even if not always easy/fully possible) and setting their (by nature) always on (and high sensitivity) microphone in your home!
On top of this, voice is considered bio-metric data as this can be used to identify single individuals. Your keyboard don't send your fingerprints to the browser at each key pressed...
Posted: Monday 07 September 2020 13:48
by EddyG
