Dashticz.setBlock not working (for me)
Posted: Wednesday 02 September 2020 22:30
by obatavier
I tried to get the value of Block_19 (Lux) into the title of Block_16 (Temp)
So the title would be like "not 0, but' XXX (were XXX is value of LUX from IDX 19)
I did the following in custom.js but seems nothing happens ?.
function getStatus_19(block) {
var idx = block.idx;
var device = block.device;
Dashticz.setBlock('16', {
title: 'not 0, but ' + device.Level,
Re: Dashticz.setBlock not working (for me)
Posted: Thursday 03 September 2020 5:29
by lzwfkv
obatavier wrote: Wednesday 02 September 2020 22:30
It should work: i have tried the code on a couple of devices of mine and it works.
I suspect that the Lux device ((your IDX=19) does not bear a "Level" attribute, therefore, can you try with this change (Level->Data):
title: 'not 0, but ' + device.Data,
You can check the actual field supported by your sensor by querying Domoticz with:
https://<your domoticz IP>:<your Domoticz port>/json.htm?type=devices&rid=19
Posted: Sunday 04 October 2020 18:31
by obatavier
Hi, thanksit looks like the function is not triggered. (The title never got changed at all)..
I tried with another device (temperature) and which does work in this function.. However it looks like my (Tado) devices for some reason do not provide a value..
I even tried to use a device switch which has values On of Off but
function getStatus_42(block){
if(device['Data']=='Off'){
block.addClass='warninglow';
Dashticz.setBlock('39_1', {
title: 'Heating On',
Seems to never trigger, no matter if I try to change if(device['Data']=='Off') to if(device['Data']=='Anything') no change in behavior.
any idea, looks like it is Tado device (which I checked does have a 'Data' field which is 'Off' or 'On' but no Dashticz updates.
(what I try is to show the temperature of a room (Block 39_1) and change the Title (or better the Icon color but not found that) when the heating of that room is 'On' (Status if device 42))
Posted: Sunday 04 October 2020 18:50
by Lokonli
obatavier wrote: Sunday 04 October 2020 18:31
Did you add device 42 to a column? Otherwise the getStatus function won't get called.
If you defined the block like:
then as function name you should use getStatus_myname
To be sure, please update to latest master or beta.
To make debugging a bit easier, you can add the following statement to the getStatus function:
In Chrome you can open DevTools by pressing F12. In the console tab you find the log messages (after refreshing Dashticz)
Posted: Sunday 04 October 2020 19:36
by obatavier
Looks like the function does not get triggered (console is empty).. I do have a block with the device,
and I do have triggers with Getstatus who do fire but strange enough not the simple On/Off devices.. ( I would expect when changing the logic like == to != I should see some difference... Maybe a type, a 'or " ?.
(And just to prepare when it triggers How to change only the Icon color of the Dashticz.SetBlock block ?.)
Posted: Sunday 04 October 2020 20:19
by obatavier
I even tried with a ON/Off filed which is currently on my
Dashboard. That one get's updated on the Dashboard from off to on , but the code in custom.js does not even fire on this Device... Not sure why, ..
Posted: Sunday 04 October 2020 20:44
by Lokonli
What is your Dashticz version?
Do you see any other error in DevTools?
Can you post your CONFIG.js and custom.js, then I'll have a look.
Posted: Sunday 04 October 2020 21:26
by obatavier
Hi, first thanks for thinking with me, really appreciated !.
I get a little bit further, seems the Block needs not only to be defined but also visible in a column to work.. in which case the function works for me now.. So I put those blocks safe away under my visible screen.
What I did:
CONFIG.js
blocks[52] = {}
blocks[52]['title'] = 'SheShed_ON';
blocks[52]['width'] = 4;
AND
columns[5]['blocks'] = [32,52]
custom.js
function getStatus_52(block){
if(device['Data']=='On'){
Dashticz.setBlock('49_1', {
title: 'SheShed Heating On',
Well if it works that's fine for me..
Now I need to figure out what to add to get the Icon color (prefer) or Font color Of block '49_1' changed
Posted: Sunday 04 October 2020 21:36
by Lokonli
yes, the block must be added to a column.
With the setBlock function you can also set the addClass parameter.
And then use the class of the addClass parameter in your custom.css to set the color.
Posted: Sunday 04 October 2020 21:40
by obatavier
Hi Lokoni, as A novice with a lot of cut and paste luck, do you have an example how to add the addclass ?
I tried a line like
block.addclass
.addclass
addclass
But none of them were accepted..
Onno
Posted: Sunday 04 October 2020 22:30
by Lokonli
In custom.css:
.redwarning .col-icon {
color: red !important;
This will make the icon red for blocks with the 'redwarning' class.
In custom.js add the following:
function getStatus_5(block) {
var status = block.device.Status;
if (status === 'On')
Dashticz.setBlock("7", {addClass: 'redwarning', title:'redwarning title'})
Dashticz.setBlock("7", {addClass: '', title:'normal title'})
In this example I use the Status field of a switch device with idx 5 to set the addClass parameter and title for a device with idx 7, depending on the switch status
