Keypad for arming / disarming a alarm
sieth
Post by sieth »
After long searching, i found a working keypad for my setup.
https://nl.aliexpress.com/item/40000902 ... 4c4dlQlwSf
Very cheap, battery powered and 433mhz.
So u can use multiple of these panels in one setup
RFID:
You cannot arm/disarm with RFID. Only disarm with RFID
After using it, domoticz automatically detects 4 devices:
Arm
Disarm
Home
Tamper
SOS is not working
This is the code I use to arm / disarm my alarm with the panel:
if uservariables['Alarm_Time_Unarm'] ~= otherdevices_lastupdate['433Disarm'] then
commandArray[#commandArray + 1]={['Variable:Alarm_Time_Unarm'] = tostring(otherdevices_lastupdate['433Disarm'])}
commandArray[#commandArray + 1]={['Alarmsysteem']='Off'}
print('Alarm Disarmed')
if uservariables['Alarm_Time_Arm'] ~= otherdevices_lastupdate['433Arm'] then
commandArray[#commandArray + 1]={['Variable:Alarm_Time_Arm'] = tostring (otherdevices_lastupdate['433Arm'])}
commandArray[#commandArray + 1]={['Alarmsysteem']='On'}
print('Alarm Armed')
if uservariables['Alarm_Time_Tamper'] ~= otherdevices_lastupdate['433Tamper'] then
commandArray[#commandArray + 1]={['Variable:Alarm_Time_Tamper'] = tostring (otherdevices_lastupdate['433Tamper'])}
print('Alarm Tampered With')
Frekkel
Re: Keypad for arming / disarming a alarm
Post by Frekkel »
How do you like the control panel?
If I want to use it in domoticz, I only need this panel or even more.
and you can also program the rf tags with this panel.
thanks in advance for your help.
robgeisink
Post by robgeisink »
I have the same one but can't see any devices except the sabotagepin on the backside of the panel . How did you connect it to domoticz???
