Mitsubishi/Panasonic airco
Posted: Monday 31 August 2020 11:42
by Dave47
Is it possible to add a Mitsubishi or Panasonic air conditioner to hardware.
We do see the possibility for a Daikin
Or is there another method to build this in Domoticz?
Re: Mitsubishi/Panasonic airco
Posted: Monday 31 August 2020 12:15
by FireWizard
Someone has to write a plug-in and that is not a quick job. So that will take at least some time.
I don't know, whether the Panasonic AC and the Mitsubishi AC have the same API or Cloud service.
A few month ago, I have been working to integrate a Panasonic AC Cloud service into Domoticz.
See:
https://www.domoticz.com/forum/viewtopi ... =Panasonic
Unfortunately this project has never been finished as the user stopped responding. Do not know why.
If this is something you want to try, I will be happy to support you and to continue this project.
Posted: Monday 31 August 2020 13:25
by joto
I have integrated my Panasonic in Domoticz using the thread FireWizard referring to as inspiration.
Posted: Tuesday 01 September 2020 23:19
by FlyingDomotic
For Mitsubishi, you may use Wemos D1 with
https://github.com/SwiCago/HeatPump on you heat pumps and
https://github.com/Masurov/Domoticz-Mit ... QTT-Plugin on Domoticz size. List of confirmed working hardware can be found at
https://github.com/SwiCago/HeatPump/issues/13
Posted: Tuesday 13 July 2021 16:31
by sdamasoc
If someone is interested I made a plugin using the panasonic cloud comfort api to control my 3 AC units:
https://github.com/sdamasoc/domoticz_pa ... _CZ-TACG1/
Posted: Monday 19 July 2021 8:55
by Derik
Edit:
Sorry did not read airco
Headpump..
For Panasonic use:
https://github.com/Egyras/HeishaMon
Much better then pana cloud.
More options and open source, without very expensive pana cloud box [ i have 1 for sale ]
Help topic:
https://gathering.tweakers.net/forum/li ... /2039112/0 [ dutch ]
Nodered and plugin to use all the functions
Posted: Wednesday 29 June 2022 14:09
by Thuis
Hello i have a silly question.
Is this only for heatpumps? Or is it also for an AC? Like an mhi SRK xx ZSX-S ?
Thanks in advance.
Posted: Wednesday 29 June 2022 20:23
by FlyingDomotic
You may use it for lot os Mitsubishi AC and heat pumps. Personally, I use them for 4 different AC models.
Full list is at
Posted: Friday 01 July 2022 0:06
by Thuis
FlyingDomotic wrote: Wednesday 29 June 2022 20:23
What are the AC models you use? Ive seen the lists, but theyre all heatpump numbers
Posted: Sunday 11 September 2022 11:08
by AimoPaukku
nevermind...
Posted: Thursday 29 September 2022 14:52
by efarmer1
is this not a HTTP command thing, istead of mqtt.
