Hi Guys,
I'm a happy user of Dashticz, have a nice dashboard running on my 10" tablet, framed, on the wall.
I came up with the idea to have a smaller one in the bedroom, so i need a new design for a smaller 5" smart screen now...
I have tried to install into a different directory, which was successfull, although i noticed there was a notification "dashticz container already exists".
I do not exactly understand what consquences that might have, but i do have a second dir "dashticz2"
The installation script found the next available port 8083 in my case.
To get a quick start in setup i copied the CONFIG.js from dashticz to dashticz2 custom dir, but there's no response at all on this port.
What have i missed and/or can i do to get this to work?
By the way, a nice tweak would be if it would be possible to bind port, config, css, etc. through a configuration so one setup would be able to serve multiple dashboards.
Marco
Dashticz - Installing a second dashboard Topic is solved
marmachine
- Domoticz version: 3.4834
- HansieNL
Re: Dashticz - Installing a second dashboard
You can use the custom_2 folder for an 2nd configuration. You have to add index2.html to the normal url.
Blah blah blah
marmachine
I've found a bit more info on the topic here https://www.domoticz.com/forum/viewtopic.php?t=17489
Guess this is exactly what i was looking for!
