Very basic off/on with timer
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi !
Im a blockly user, but blockly does not support seconds, so im out of luck there :/
Im looking for a very basic script, turning switch off->on defined number of times with defined interval. Is this done how ?
Thank you in advance :)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
snellejellep
Re: Very basic off/on with timer
Post by snellejellep »
does the timer function of a switch not fill your needs?
tontze
Post by tontze »
snellejellep wrote: Friday 28 August 2020 20:07 does the timer function of a switch not fill your needs?
Nope, i need seconds :) Otherwise i would have been doing it with blockly ..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze wrote: Friday 28 August 2020 20:43
What should trigger the actions ?
snellejellep
you can do it in dzvents with for example <switchname>.switchOff().afterSec(5) which switches it off after 5 seconds
tontze
Post by tontze »
waaren wrote: Friday 28 August 2020 20:59
certain time of day, like 20:00, switch is on, then it switches off and on 6 times in 1 sec interval, and stays on.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
snellejellep wrote: Friday 28 August 2020 21:00 you can do it in dzvents with for example <switchname>.switchOff().afterSec(5) which switches it off after 5 seconds
Il look in to it, thnx
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
snellejellep
tontze wrote: Friday 28 August 2020 22:00
this should do the trick, turning it on and off 6 times and then leaving it on at 20:00
i assumed it would be a lamp so called it that but you can fill in the name of the switch you want to use in place of yourlampnameoridx
    on ={
        timer={
            'at 20:00' -- the time at which this script should trigger
    execute = function(dz, device)
        local lamp          = dz.devices("yourlampnameoridx")
        lamp.switchOn()
        lamp.switchOff().afterSec(1)
        lamp.switchOn().afterSec(2)
        lamp.switchOff().afterSec(3)
        lamp.switchOn().afterSec(4)
        lamp.switchOff().afterSec(5)
        lamp.switchOn().afterSec(6)
        lamp.switchOff().afterSec(7)
        lamp.switchOn().afterSec(8)
        lamp.switchOff().afterSec(9)
        lamp.switchOff().afterSec(10)
        lamp.switchOn().afterSec(11)
tontze wrote: Friday 28 August 2020 21:59 certain time of day, like 20:00, switch is on, then it switches off and on 6 times in 1 sec interval, and stays on.
dzVents version
return
	on =
		timer =
			'at 20:00',
	execute = function(dz)
	    light = dz.devices('Flicker')
	    for i = 0, 12, 2 do
	        light.switchOff().afterSec(i)
	        light.switchOn().afterSec(i + 1)
Classic Lua version (save with trigger type timer)
local executionTime = '20:00'
local light = 'Flicker' -- Name of your light
if os.date('%H:%M') == executionTime then
     for i = 0, 12, 2 do
        commandArray[#commandArray + 1] = { [light] = 'Off AFTER ' .. i }
        commandArray[#commandArray + 1] = { [light] = 'On AFTER ' .. (i + 1) }
Blockly (save with trigger type timer)
