Selecting Persistent data variables based on a number (SOLVED)
Posted: Wednesday 26 August 2020 17:03
by wizzard72
For example I have 4 persistent data variables:
data = {
		myVar1 = { initial = 0,history = true, maxItems = 20 },
		myVar2 = { initial = 0,history = true, maxItems = 20 },
		myVar3 = { initial = 0,history = true, maxItems = 20 },
		myVar4 = { initial = 0,history = true, maxItems = 20 },
I want to select one of the persistent data variables based of the last digit.
With domoticz.devices() this is possible, for example:
deviceStartName = "Light"
for i = 1, 4, 1 do
	domoticz.devices(deviceStartName .. i).dimTo(25)
How to do something similair with persistent data variables? If loopting through the persistent data variables names is possible, this is also a solution for me.
Re: Selecting Persistent data variables based on a number
Posted: Wednesday 26 August 2020 17:10
by wizzard72
Normal code to add data to the persistent data variable:
domoticz.data.myVar1.add(sensor.data)
If the persistent data variable is used like this it's solved my problem:
domoticz.data('myVar1').add(sensor.data)
Posted: Wednesday 26 August 2020 17:54
by waaren
wizzard72 wrote: Wednesday 26 August 2020 17:03 How to do something similar with persistent data variables? If looping through the persistent data variables names is possible, this is also a solution for me.
Please note that initial = has no meaning for historic persistent data and is therefore ignored.
As most other objects in dzVents, persistent historic data is a Lua table. Lua table with a string type key can be accessed via two different styles (the one without brackets is so called " Syntax sugar")
dz.data.myVar1.data = dz.data.myVar1['data'] = dz.data['myVar1'].data = dz.data{'myvar' .. 1][data] -- etc..
Hope below example helps understanding
return
    on =
        timer =
            'every minute',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = ' persistent' ,
    data =
        myVar1 = { history = true, maxItems = 4 },
        myVar2 = { history = true, maxItems = 3 },
        myVar3 = { history = true, maxItems = 2 },
        myVar4 = { history = true, maxItems = 5 },
    execute = function(dz, item)
        for i = 1, 4 do
            dz.data[ 'myVar'  .. i ].add( i * dz.time.minutes )
        dz.log('Raw Date Time of first  record in myVar4: ' .. dz.data.myVar3.getOldest().time.raw,dz.LOG_DEBUG) -- direct access via
        for i = 4, 1, -1 do
            dz.log(dz.data[ 'myVar' .. i ]['getOldest']().data,dz.LOG_DEBUG)
Posted: Wednesday 26 August 2020 19:47
by wizzard72
Hi @waaren, thank you so much!!! I was struggeling with this for some time.
Learned something today :-)
