second Youless does not appear as Device/Utility
Posted: Wednesday 19 August 2020 19:47
Since this week I'm using domoticz together with dashticz to get a nice overview of all the smart devices in and arround my home.
My domoticz is running on a Synology NAS, and I'm using version: 2020.2 (build 12213)
One thing I cannot figure out is the following:
I got a Youless LS110 which is checking my Gas usage, this device I add via Hardware, and is showing in the device list and works fine.
My other Youless LS120 which is monitoring my overall power usage, I added like the same way as the LS110 (different IP address) but that Youless is not showing in the device list. The Device is enabled, I can browse to it using the IP address. It is also working fine in sending the data towards PVO.
The LS120 Youless is flashed with the latest PVoutput firmware (1.3.4-PO2), the LS110 is flashed with firmware 1.2.0-G4
Are there other ways I can add the LS120 so I can use the usage info together with the solar generation info to get a nice graph in dasticz ?
Or what can I do to check if I can add this LS120 device?
In the logfile I can see:
2020-08-19 19:50:09.028 Error: YouLess: Error connecting to: 192.168.1.20
2020-08-19 19:50:19.031 (YouLess LS110 (MinderGas.nl)) YouLess Meter (YouLess LS110 (MinderGas.nl))
When I delete the LS120, the error is gone. But the LS110 message still is showing, so that might be an info message.
