Heating control script not acting as expected
Posted: Sunday 16 August 2020 22:35
I have this heating control script.
What I expect the script to do is whenever I switch the heating on manually with the CV_switch_auto and the temperature is above the setpoint, is that it does not switch on
However what it does is wait till 0, 15, 30, 45 minutes (the interval) to test.
So when it is toggled to 'on' it starts burning.
What am I overlooking in the above script.
I made another manual switch which toggles the heating on during 5 minutes (in case it is chilly in the house)
This one works as expected.
I know there are many ways of firing the heating with hysteresis and everything.
The script I made initiates heating and then waits 5 or 10 minutes to give the heat in the radiators the chance to heat up the room.
That's why this system has a 15 minutes interval for probing the temperature in the room.
-- assumptions:
-- the setpoint is set by a dummy device (not a selector type)
local CV_SWITCH = 'CV_switch_auto' -- switch device
local TEMP_SETPOINT = 'Thermostaat_setpoint' -- selector dummy device
local TEMP_SENSOR_1 = 'TFA1'
local TEMP_SENSOR_2 = 'Oregon'
local BAT_THRESHOLD = 30
local LOGGING = true
return
on =
timer =
'every 15 minutes'
--LOG levell: This is the log level you want for this script. Can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
--marker: A string that is prefixed before each log message. That way you can easily create a filter in the Domoticz log to see just these messages.
logging =
level = LOGGING and domoticz.LOG_DEBUG or domoticz.LOG_ERROR,
--level = LOGGING and domoticz.LOG_ERROR,
marker = 'dzVents heating',
execute = function(dz)
-- collect all input data
local boiler_switch_state = dz.devices(CV_SWITCH).state
local temp_1 = dz.devices(TEMP_SENSOR_1).temperature
local temp_2 = dz.devices(TEMP_SENSOR_2).temperature
local bat_1 = dz.devices(TEMP_SENSOR_1).batteryLevel
local bat_2 = dz.devices(TEMP_SENSOR_2).batteryLevel
local setpointValue = dz.devices(TEMP_SETPOINT).setPoint
local average_temp = 40 -- very high so the heating will not fire
local temp_diff = temp_1 - temp_2
-- info only on log level = LOG_DEBUG
dz.log('CV_SWITCH : ' .. boiler_switch_state, dz.LOG_DEBUG)
dz.log('Temp_1 : ' .. temp_1, dz.LOG_DEBUG)
dz.log('Temp_2 : ' .. temp_2, dz.LOG_DEBUG)
dz.log('Bat_1 : ' .. bat_1, dz.LOG_DEBUG)
dz.log('Bat_2 : ' .. bat_2, dz.LOG_DEBUG)
dz.log('Setpoint_value : ' .. setpointValue, dz.LOG_DEBUG)
-- test if conditions are met and set acting values
if ((temp_1 - temp_2 > 1.1) or (temp_2 - temp_1 > 1.1)) then
dz.log('Temperature difference between sensors is more than 1.1 degrees : ' .. temp_diff, dz.LOG_DEBUG)
dz.notify('Notifyer', 'Temperature difference between sensors is more than 1.1 degrees' .. temp_diff , dz.PRIORITY_HIGH)
elseif (bat_1 < BAT_THRESHOLD) then
dz.log('Battery level of temperature sensor 1 = ' .. bat_1, dz.LOG_DEBUG)
dz.notify('Notifyer', 'Temperature sensor 1 ' .. bat_1 .. 'battery level low.',dz.PRIORITY_HIGH)
elseif (bat_2 < BAT_THRESHOLD) then
dz.log('Battery level of temperature sensor ' .. bat_2, dz.LOG_DEBUG)
dz.notify('Notifyer', 'Temperature sensor 2 ' .. bat_2 .. 'battery level low.',dz.PRIORITY_HIGH)
average_temp = (temp_1 + temp_2)/2
dz.log('Average temperature sensors value is : ' .. average_temp, dz.LOG_DEBUG)
-- now determine what to do
if (average_temp >= setpointValue) then
dz.devices(CV_SWITCH).switchOff()
dz.log('Target temperature reached, boiler off')
elseif (average_temp <= (setpointValue -1)) then
dz.log('Average temperature more than 1 degree below setpointValue, switchOn during 10 minutes')
dz.devices(CV_SWITCH).switchOn().forMin(10)
elseif ((average_temp > (setpointValue -1)) and (average_temp < setpointValue)) then
dz.log('Average temperature less than 1 degree below setpointValue, switchOn during 5 minutes')
dz.devices(CV_SWITCH).switchOn().forMin(5)
else -- not predicted situation
dz.log('Unpredicted situation, boiler off')
devices = { 'CV_switch_manual' }
execute = function(domoticz, TriggeredItem)
if (TriggeredItem.active) then -- state == 'On'
--domoticz.notify('Boiler switch is switched on manually', domoticz.PRIORITY_LOW)
TriggeredItem.switchOff().afterMin(5) -- if it is a switch
--domoticz.notify('The Boiler switch ' .. TriggeredItem.name .. ' will be switched off after 5 minutes')
}I know there are many ways of firing the heating with hysteresis and everything.
