Neo Coolcam NAS-WR01ZE wrong usage (KWh) values
Posted: Sunday 16 August 2020 18:02
I'm tracking down some issue on the new NAS-WR01ZE plugs. I'm have some problems and it looks like i'm the only one, can't find anything about it anywhere on the internet. I'm well aware of the negative values it sends. Thats what i'm not refering to.
It's specificly about the newer plugs with ID: 0x1027 and Type: 0x0602. The usage (KWh) value is 3x times as high as it should be. After 1 hour of constanly taken 1Kwatt the usage counter increases by 3.00KWh. I also noticed my firmware version is different then others.
My questions if you have a NAS-WR01ZE plugs with Id:0x1027 and Type:0x0602.
1. Do you also experience this problem the usage is (3x) too much?
2. What application version does you plug(s) have?
My Plugs (3 pieces):
Type: 0x0602
Protocol Version: 6.04
Application Version 2.23 (2 pieces, with usage too high)
Application Version 2.21 (1 piece, with usage too high)
Regards,
Richard Dols
Type: 0x0602
Regards,
Richard Dols
