Shelly plugin deleted -> problem for Domoticz
Posted: Sunday 16 August 2020 15:20
by Tukker
I had a Shelly plugin which I deleted from ~/domoticz/plugins
Now my log file shows
 2020-08-16 15:01:59.170 Error: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-08-16 15:01:59.170 Error: (Shelly) Module Import failed, exception: 'ModuleNotFoundError'
2020-08-16 15:01:59.170 Error: (Shelly) Module Import failed: ' Name: plugin'
2020-08-16 15:01:59.170 Error: (Shelly) Error Line details not available.
followed by a line every 15 seconds
2020-08-16 15:15:20.288 Error: Shelly hardware (10) thread seems to have ended unexpectedly
How can I undo this?
Re: Shelly plugin deleted -> problem for Domoticz
Posted: Sunday 16 August 2020 15:32
by FireWizard
@HvdW
Did you also delete the plugin from your "hardware" in Domoticz (Setup > Hardware)?
Posted: Sunday 16 August 2020 17:42
by Tukker
I can click and reach all menus except Hardware.
Clicking on Hardware does not give a reaction.
Posted: Sunday 16 August 2020 21:51
by FireWizard
Hi, @HvdW
This is a different problem, which I never have seen before. Anyone?
But indirectly, you answered my question. You did not delete the plugin in Hardware.
You should first repair the access to the "Hardware" in the Setup menu and then delete the plugin.
However I don't know, yet, what the reason for that is.
Posted: Sunday 16 August 2020 21:57
by Tukker
Domoticz turned into a state unreachable in the web interface.
I restarted it several times.
Hardware showed up.
Deleted Shelly.
Logs are clean now.
Thanks a lot.
I was at the brink of installing a RPI backup.
