Turn on two devices one after the other
Posted: Saturday 15 August 2020 12:14
by Quax1507
Hello community,
I am trying to turn on two devices (garden irrigators) one after the other unsing one trigger.
The two relevant code lines are:
if [...]
  irrigator1.switchOn().forMin(10)
  irrigator2.switchOn().afterMin(10).forMin(10)
elseif [...]
Both irrigators should be activated for 10 minutes - one after the other.
Using the commands above, they are turned on at the same time, but I don't really undertsand why...
Any idea?
Quaxx
Re: Turn on two devices one after the other
Posted: Saturday 15 August 2020 13:43
by waaren
Quax1507 wrote: Saturday 15 August 2020 12:14 Using the commands above, they are turned on at the same time, but I don't really undertsand why...
I cannot replicate this on my test system (V2020.2 build 12242, dzVents 3.0.11) My test script does trigger the test lights as- and when expected (see below for script and log)
What is your domoticz / dzVents version?
What is the the hardware, devicetype and subtype of these devices?
    on =
        devices =
            'testFor',
            'testLamp1',
            'testLamp2',
    logging =
        level = domoticz.LOG_DEBUG,
        marker= 'testFor',
    execute = function(dz, item)
        local tester = dz.devices('testFor')
        local l1 = dz.devices('testLamp1')
        local l2 = dz.devices('testLamp2')
        dz.log('State of ' .. l1.name .. ' is ' .. l1.state,dz.LOG_DEBUG )
        dz.log('State of ' .. l2.name .. ' is ' .. l2.state,dz.LOG_DEBUG )
        if item == tester then
            l1.switchOn().forMin(2)
            l2.switchOn().afterMin(2).forMin(2)
log from script
2020-08-15 13:18:16.777  Status: User: Admin initiated a switch command (480/testFor/On)
2020-08-15 13:18:16.781  (Virtual) Light/Switch (testFor)
2020-08-15 13:18:16.821  Status: dzVents: Info: Handling events for: "testFor", value: "On"
2020-08-15 13:18:16.821  Status: dzVents: Info: testFor: ------ Start internal script: 20200815 dz testFor: Device: "testFor (Virtual)", Index: 480
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp1: Switch device adapter
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp2: Switch device adapter
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: State of testLamp1 is Off
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: State of testLamp2 is Off
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Constructed timed-command: On
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Constructed timed-command: On FOR 120 SECONDS
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Constructed timed-command: On AFTER 120 SECONDS
2020-08-15 13:18:16.822  Status: dzVents: Debug: testFor: Constructed timed-command: On AFTER 120 SECONDS FOR 120 SECONDS
2020-08-15 13:18:16.823  Status: dzVents: Info: testFor: ------ Finished 20200815 dz testFor
2020-08-15 13:18:16.830  (Virtual) Light/Switch (testLamp1)
2020-08-15 13:18:16.865  Status: dzVents: Info: Handling events for: "testLamp1", value: "On"
2020-08-15 13:18:16.865  Status: dzVents: Info: testFor: ------ Start internal script: 20200815 dz testFor: Device: "testLamp1 (Virtual)", Index: 478
2020-08-15 13:18:16.866  Status: dzVents: Debug: testFor: Processing device-adapter for testFor: Switch device adapter
2020-08-15 13:18:16.866  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp2: Switch device adapter
2020-08-15 13:18:16.866  Status: dzVents: Debug: testFor: State of testLamp1 is On
2020-08-15 13:18:16.866  Status: dzVents: Debug: testFor: State of testLamp2 is Off
2020-08-15 13:18:16.866  Status: dzVents: Info: testFor: ------ Finished 20200815 dz testFor
2020-08-15 13:20:16.862  (Virtual) Light/Switch (testLamp1)
2020-08-15 13:20:16.874  (Virtual) Light/Switch (testLamp2)
2020-08-15 13:20:16.901  Status: dzVents: Info: Handling events for: "testLamp1", value: "Off"
2020-08-15 13:20:16.901  Status: dzVents: Info: testFor: ------ Start internal script: 20200815 dz testFor: Device: "testLamp1 (Virtual)", Index: 478
2020-08-15 13:20:16.901  Status: dzVents: Debug: testFor: Processing device-adapter for testFor: Switch device adapter
2020-08-15 13:20:16.902  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp2: Switch device adapter
2020-08-15 13:20:16.902  Status: dzVents: Debug: testFor: State of testLamp1 is Off
2020-08-15 13:20:16.902  Status: dzVents: Debug: testFor: State of testLamp2 is Off
2020-08-15 13:20:16.902  Status: dzVents: Info: testFor: ------ Finished 20200815 dz testFor
2020-08-15 13:20:16.940  Status: dzVents: Info: Handling events for: "testLamp2", value: "On"
2020-08-15 13:20:16.940  Status: dzVents: Info: testFor: ------ Start internal script: 20200815 dz testFor: Device: "testLamp2 (Virtual)", Index: 479
2020-08-15 13:20:16.940  Status: dzVents: Debug: testFor: Processing device-adapter for testFor: Switch device adapter
2020-08-15 13:20:16.941  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp1: Switch device adapter
2020-08-15 13:20:16.941  Status: dzVents: Debug: testFor: State of testLamp1 is Off
2020-08-15 13:20:16.941  Status: dzVents: Debug: testFor: State of testLamp2 is On
2020-08-15 13:20:16.941  Status: dzVents: Info: testFor: ------ Finished 20200815 dz testFor
2020-08-15 13:22:16.834  (Virtual) Light/Switch (testLamp2)
2020-08-15 13:22:16.874  Status: dzVents: Info: Handling events for: "testLamp2", value: "Off"
2020-08-15 13:22:16.875  Status: dzVents: Info: testFor: ------ Start internal script: 20200815 dz testFor: Device: "testLamp2 (Virtual)", Index: 479
2020-08-15 13:22:16.875  Status: dzVents: Debug: testFor: Processing device-adapter for testFor: Switch device adapter
2020-08-15 13:22:16.876  Status: dzVents: Debug: testFor: Processing device-adapter for testLamp1: Switch device adapter
2020-08-15 13:22:16.876  Status: dzVents: Debug: testFor: State of testLamp1 is Off
2020-08-15 13:22:16.876  Status: dzVents: Debug: testFor: State of testLamp2 is Off
2020-08-15 13:22:16.876  Status: dzVents: Info: testFor: ------ Finished 20200815 dz testFor
Posted: Saturday 15 August 2020 18:13
by Quax1507
I am on Build 12240 and ended up doing this:
if [...]
  irrigator1.switchOn().afterSec(1).forMin(10)
elseif [...]
This works without any problems so far...
Little difference: my trigger is a time. Perhaps the reason?
Posted: Saturday 15 August 2020 18:44
by waaren
Quax1507 wrote: Saturday 15 August 2020 18:13 Little difference: my trigger is a time. Perhaps the reason?
Not likely. I also tested with a timer as trigger: same result. Also strange that it now works with the extra afterSec() while the initial afterMin() seem to have been ignored.
Can you share the log for both situations? Also what is the hardware, devicetype and subtype?
Re: Turn on two devices one after the other  [Solved]
Posted: Sunday 16 August 2020 11:25
by Quax1507
I did some more testing and I found the reason :o
I used "irrigator2.switchOn().aftermin(10).forMin(10)"
instead of "irrigator2.switchOn().afterMin(10).forMin(10)"
Stupid typo!
Thank You for Your support!!
