installing SBFspot 3.7.0 on Pi 4
Posted: Friday 14 August 2020 10:25
by Mathiasdb
Hi guys,
I want to integrate my sunnyboy 3.6 into my domticz system.
I am following the instructions on github and everything goes well, untlill I have to download the latest version of the sourcecode of sbfspot:
"failed:The network is unreachable."
I tried many differtent options by chaniging the url, without any succes...
Anyone ideas?
Grtz,
Mathias
Re: installing SBFspot 3.7.0 on Pi 4
Posted: Friday 14 August 2020 10:34
by FireWizard
What is the URL you want to download from?
I'm able to download files from:
https://github.com/SBFspot/SBFspot/releases.
Posted: Friday 14 August 2020 10:48
by Mathiasdb
Hi FireWizard,
I use the same site, URL (by clickin on sourcecode (tar.gz): command:
"wget
https://codeload.github.com/SBFspot/SBF ... .gz/V3.7.0"
But i get message 443...failed: The network is unreachable.
Can you give me the exact command?
Grtz!
Posted: Friday 14 August 2020 16:44
by Mathiasdb
Now I noticed that I can download the files using google chroom on my desktop, (this morning it went wrong even on the desktop)
But when I try to download the sourcecode with the Pi, i still get the notification that the netwerk is unreachable.
I rebooted the pi and tried again, same problem.
How bizar!
Posted: Friday 14 August 2020 21:38
by FireWizard
@Mathiasdb
I was able to download it on a RPi with the following command:
wget
https://github.com/SBFspot/SBFspot/rele ... ter.tar.gz
This is just an example, as there are many releases available.
See:
For the source code, you can try: wget
https://github.com/SBFspot/SBFspot/arch ... 7.0.tar.gz
Posted: Wednesday 26 August 2020 15:55
by Mathiasdb
Thank You FireWizard!
But no succes...
I don't know what else to try ...
I think my knowledge of linux is lacking...
thanks anyway!!
Grtz!
Posted: Wednesday 26 August 2020 19:18
by FireWizard
@Mathiasdb
But no succes...
thanks anyway!!
Are you giving up?
Question; Has wget been installed?
If not:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install wget
If it is already installed, you will see:
Reading package lists... Done
Building dependency tree
Reading state information... Done
wget is already the newest version (1.20.1-1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
If no, it will be installed.
Afterwards try again:
wget https://github.com/SBFspot/SBFspot/archive/V3.7.0.tar.gz
Posted: Friday 05 February 2021 16:43
by Mathiasdb
Hi Fire-wizzard
I tried to install the SBF-spot again (V3.7.1)
I did the update and upgrade, I re-installed de wget (was already installed)
Still the same problem:
mdb@Domoticz:~ $ sudo wget
https://github.com/SBFspot/SBFspot/arch ... 7.1.tar.gz
--2021-02-05 16:35:35--
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... failed: Network is unreachable.
On my desktop, there's no problem downloading the file.
Is there an other way?
Grtz!
Posted: Saturday 06 February 2021 16:11
by erem
why don't you use winscp to move the file to your pi from your desktop
https://winscp.net/eng/download.php
Posted: Saturday 06 February 2021 21:13
by FireWizard
Hi @Mathiasdb,
I tried to install both versions v3.7.0 and 3.7.1 en it installed immediately on my pi.
IP address is okay. Could it be that your Pi is not online or that a Firewall is preventing the connection?
It is not necessary to install it with sudo. But is does no harm, only that the file will be owned by root:root
Another way is possible, e.g scp (or in Windows Winscp)
Posted: Monday 08 February 2021 21:04
by Mathiasdb
Hi Erem and Firewizard,
The WinSCP wat a great tip. now I understand better what i'm doing in the pi.
I Think I installed everythin, I followd the manual on github. I had connection between the pi and SMA.
Now , I hope to see the SBF-spot-sensor working on domoticz tomorrow!!
I read there where several problems in the past with the sensor in domoticz. Are they solved? or do you guys have tips?
Thank you verry much so far!
Grtz,
Posted: Tuesday 09 February 2021 16:48
by FireWizard
Hello @Mathiasdb,
I do not own a SMA inverter, so I don't use SBF-spot. So I can't tell you, if there are issues. I do not have any tips. So I quit.
Posted: Monday 15 February 2021 15:33
by Mathiasdb
Hi Firewizard,
It Works!!
Thank you verry much!!
