Byron Smartwares DBY-23712 wireless doorbell support (Action)
georon
Domoticz version: Bèta
Post by georon »
Hello all,
I bought a wireless doorbell from Action today and I am unsuccessfull to connect this one to Domoticz.
Anyone has tried this before?
When I press the push button with rfxmngr in undec mode, the response for a single push is:
13-8-2020 04:17:27:726= 0A03010030898085D30802
Packettype        = UNDECODED RF Message
UNDECODED ARC:30898085D30802
13-8-2020 04:17:28:278= 0A03010130898085D30805
UNDECODED ARC:30898085D30805
13-8-2020 04:17:28:604= 05030C020180
UNDECODED NEC:0180
Example of a second push:
13-8-2020 04:25:44:942= 05030C0303E0
UNDECODED NEC:03E0
13-8-2020 04:25:45:487= 0A0301043018BBD59307FB
UNDECODED ARC:3018BBD59307FB
13-8-2020 04:25:45:817= 0A0301053018BBD59307FD
UNDECODED ARC:3018BBD59307FD
FireWizard
Re: Byron Smartwares DBY-23712 wireless doorbell support (Action)
Post by FireWizard »
See: https://www.domoticz.com/forum/viewtopi ... dy#p250849
You can try as well or contact RFXCom helpdesk.
Joep123
Post by Joep123 »
Did you find a solution? I have to same doorbell but I am unable to connect the doorbell to Domoticz (via RFXCOM).
jefft
Domoticz version: 2023.1
Post by jefft »
The BY chimes (I think DBY is same) are better supported in the recent betas - I sent gizmocuz a BY chime set to play with and he helped me with some changes to how they're handled. It's now possible to receive and send each of the range of tunes individually or use a domoticz group to catch them all as one. If you look at the closed issues on the domoticz github, you'll find more details.
Happy to try to help if you've other Byron questions :-)
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
WvdM78
Post by WvdM78 »
I have bought this Byron DBY-23712 as well and cannot get it to work with Domoticz (RFLink). I have the latest Domoticz beta (2020.2 12393) installed. I suspect it is not communicating with Byron SX but something else. When I try to manual learn the speaker in the first 20 seconds and send a command via the Byron SX protocol in Domoticz, it doesn't respond.
Any ideas how to check which protocol is used?
