Aqara vibration sensor
Posted: Thursday 13 August 2020 11:51
by GilbertvH
I've paired an Aqara vibration sensor to my Zigate but how can I adjust the sensitivity?
Re: Aqara vibration sensor
Posted: Thursday 13 August 2020 12:37
by Damsee
You need to set the paramter through the Zigate web admin page which should be available at http://yourIP:9440/
Go to "Settings" and you should get the following:
Documentation is available : https://github.com/pipiche38/Domoticz-Z ... nf.json.md
You can set the sensitivity to low, medium, high
Posted: Thursday 13 August 2020 13:06
by GilbertvH
Damn... Missed that one! Thanks!
Posted: Monday 26 October 2020 8:42
by dheuts
I have two of these, connected with Zigbee2mqtt.
One of the sensors is going back to Off after one second, the other one stays on Vibration or Tilt, so I have to put it back to off state with a Blockly command after a couple of seconds after movement.
What is normal behaviour? How does it work at your places?
Any idea how to get them both working the same way?
