Live status does not work? Aeotec...
Posted: Wednesday 12 August 2020 9:44
by binbo
I switched to z-wave for the "live status" / "reporting if the device is ON or OFF"
This doesn't seem to work - All of my devices are Aeotec z-wave+ devices - and i have the aeotec z-stick
But in Domoticz - if I manually go and press a switch to "ON" on a smart switch 6 - Domoticz does not know about the new state. Even if i refresh the page. It doesn't get told.
Can anyone help?
Thanks.
Re: Live status does not work? Aeotec...
Posted: Tuesday 01 September 2020 21:23
by binbo
Anyone?
This is main reason I switched to z-wave
Posted: Tuesday 01 September 2020 22:19
by kiddigital
Look in the Z-Wave console (in Domoticz) to see if the device status reflects the actual situation.
Z-wave is capable of keeping things in sync but it also depends on what is actually implemented in the devices.
First figure out if your z-wave controller (the stick) is aware of the actual state. Otherwise Domoticz can not know this.
Posted: Tuesday 22 September 2020 23:37
by binbo
I finally managed to check this - thanks for the idea @kiddigital!
In my OpenZWave control panel - all devices are reporting correctly - but in domoticz - some are showing as “ON” when they are off, and they are correctly reported as off in OZW.
What does this mean? And what can I do?
Many thanks.
Posted: Tuesday 06 October 2020 18:35
by AntoonvdOetelaar
Yes I have the same issue, it was introduced after the newer OZW1.6.
Posted: Sunday 25 October 2020 17:49
by binbo
Any way to fix this anyone?
It kind of takes away the best feature of z-wave.
Posted: Sunday 25 October 2020 18:40
by kiddigital
binbo wrote:Hi,
Many thanks.
Can you provide some screenshots of the OZW panel before and after switching.. same for the corresponding device in Domoticz and post the Domoticz log (preferably with Debug enabled, see startup parameters) of that time-window?
Posted: Monday 26 October 2020 19:22
by Treve
Is your RPi a 3 or 4?
Aeotec 5 Z-Wave stick knows problems with RPi 4.
Posted: Monday 26 October 2020 19:46
by Arkie
I have the same issues, but running domotiz on my synology.
I even tried to make a fresh install of domoticz, my database and zwave components.
But still facing the issues
Posted: Monday 26 October 2020 19:51
by Treve
Aeotec Gen5 stick nows problems with USB 3 ports, it can be solved to use a USB 2 Hub.
This is what I read on Internet.
Posted: Monday 26 October 2020 20:37
by jumbotroll
Arkie wrote: Monday 26 October 2020 19:46
Have you tested to use the USB 2.0 port in the front of DS412+ ?
Posted: Tuesday 27 October 2020 15:09
by Arkie
My z-wave stick is in the front usb port
Posted: Sunday 08 November 2020 14:36
by binbo
Cheers guys - I will find pi model, usb info, and get logs and stuff when I get home.
But...
I’ve got a feeling it’s not a usb 3 issue, or even a pi model issue - as the z-stick is reporting correct status to OZW
The status is always correct in OZW.
It makes me suspect it’s the link between ozw and domoticz.
But... I’ll get and provide info very soon
Many thanks.
Posted: Thursday 19 November 2020 6:12
by ropske
any update on this?
seems multiple people are having this problem (see different topics)
https://domoticz.com/forum/viewtopic.ph ... 7&p=260824
Posted: Sunday 14 February 2021 14:24
by binbo
Bit of a late reply - but I’m in same situation.
It’s 100% domoticz issue not talking to OZW.
Z-wave devices report perfect in open z-wave control panel.
In domoticz - it’s not working.
It’s not a usb3 or pi issue - as like I said, ozw is working fine.
