ZW132 Nano switch configuration
Posted: Sunday 09 August 2020 10:23
by HarryB
Hi Team,
I have included an Aeotec ZW132 double nano switch, it is used to control watering.
What I try to set is a timer, in case that Domoticz would crash, the garden will not be flooded.
There are parameters for that but I really don't understand what it says.
There is no example to makes things clear, would like to put this on 1 hour.
Guess I would need to set parameter 87
Parameter 87: Set appointment 2
Set the OFF time of output load.
Size: 4 Byte, Default Value: 8327680
Setting Description
0 - 60 The minute value of ON time
256 - 316 The hour value of ON time
65536 - 65543 The day value (Mon to Sun)
16777215 Disable the setting.
16777216 Enable the setting.
Any help is welcome
Harry
Version: 2020.2 (build 12221)
Build Hash: 74c0c9fcc-modified
Compile Date: 2020-07-12 10:47:23
dzVents Version: 3.0.11
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Aeotec ZW100 USB
RFXCOM - RFXtrx433
