Page 1 of 2
Integrating control of my Velux windows into Domoticz
Posted: Thursday 11 September 2014 8:37
by StanHD
Hi All,
Velux windows operate under a system called "ioHomecontrol". Although this is incompatible with the rfxtrx433, they also offer an interface that can instruct the basic functions by using 2 simple digital on/off inputs. (Velux klf 100).
A pulse to 1 input closes, the other opens, and both together stops.
My question is does anyone know of a usb connected relay board that I can control via domoticz? This way I could locate the board and interface local to my nuc and broadcast instructions via the Velux interface.
My system: Domoticz running under Windows on nuc.
Re: Integrating control of my Velux windows into Domoticz
Posted: Friday 12 September 2014 15:44
by leplan73
I'm working on the support of Yoctopuce USB actuators (i.e. relay) and sensors. I have submitted a first patch to the authors.
Posted: Friday 12 September 2014 20:22
by StanHD
I decided to bite the bullet an ordered one of these:
http://www.robot-electronics.co.uk/htm/eth008tech.htm
Will report back how it goes.
Posted: Saturday 13 September 2014 9:45
by simonrg
Looks interesting device, not quite sure how you are going to use it with ioHomecontrol.
I guess you are going to use the ETH008 to control the KLF100, and connect to Domoticz by sending http commands to the ETH008.
The Velux documentation takes you in details through particular operations, without really giving an overview of what the device can do, so as with much of the Velux documentation, having read the KLF100 instructions I am not sure how many devices it can connect to or quite how to connect to it. It looks like it should be able to open / close all my blinds as 1 group, but almost implies if I want to control by windows as well, then I need to buy another KLF100. Am I missing something?
My plan is to take a ioHomecontrol relay apart and wire it up to PiFace in order to control directly from Domoticz/Raspberry Pi, a bit cludgey as you need to press buttons multiple time in order to navigate menus and obviously only feedback is on the remote control screen. I haven't yet quite worked out whether I can get away with using simple outputs on the PiFace or whether I need to use the relays, which would limit me to 2 buttons.
Posted: Saturday 13 September 2014 11:28
by StanHD
My idea is indeed to use the klf-100. I think you are right, and from my research this will only control 1 group. In my case this is fine as my Velux are both in one high vaulted room and we always operate as a group. Also in the same room we have a reversible ceiling fan that we have installed for both cooling in one direction and de-stratification in the other. The supplied rf remote does not play with the RFXTRX433, so I have obtained a second remote control which I have torn apart, and similar perhaps to your idea, I will solder wires to the required tracks. Using low level, high level, and outside temperature sensors, I might try a simple control script / blocky to automate the component actions. For example, outside temp > x = open Velux. Or maybe control the de-stratification fan using the temperature differences of the internal sensors. Either way it should all be great fun.
Posted: Saturday 13 September 2014 13:29
by simonrg
All sounds good, just not going to be cheap with the KL100 @ £100 and the ETH008 @ £50.
Looking forward to hearing how it all goes.
Posted: Thursday 18 September 2014 12:49
by StanHD
Progress Update:-
Got the Relay board, connected the ethernet, gave it 12v DC, instantly available via "
http://eth008"
Checked the default config and for now switched off the HTTP Authentication.
Tested the relays from the on-board webapp, all working
Next I fixed the IPA address.
Upgraded the firmware using the provided (download) updater to V5. This allows ASCII:-
ASCII text commands DOA and DOI (V4+ firmware needed)
Following customer request we have added a feature that allows the outputs to be switched using an ASCII string, devices like a Mobotix camera can now switch relays with simple strings.
The string for activating output1 for 5 seconds is formatted using comma seperated variables with the following syntax:
":DOA,1,50,password"
To break this down ":" (hex 3A) at the start of the string indicates that there is an ASCII message to follow, "DOA" is digital output active, "1" is the output number, then "50" for 5 seconds (50x100ms) and finally the TCP password (if applicable).
If I wanted to make output 2 inactive for 3 seconds I would use:
":DOI,2,30,password"
To break this down ":" (hex 3A) at the start of the string indicates that there is an ASCII message to follow, "DOI" is digital output inactive, "2" is the output number, then "30" for 3 seconds (30x100ms) and finally the TCP password (if applicable).
Assuming no password is used the previous command would simply be:
":DOI,2,30 "
Now for Domoticz:-
Works perfectly
Have already tested with the ceiling fan temporarily connected. The KLF 100 (Velux Interface) just arrived today, and I have just ordered an enclosure.
Will report more progress soon.
Posted: Thursday 12 March 2015 16:23
by pascalspits
Is there a way to detect the status of the relays on the ETH008 ?
when I make a dummy switch in Domoticz (like you did, above here) I can control the relay with it, no problem, but without any feedback ...
although when switch on 1 relay with Domoticz and then I open the URL application of the ETH008 I can see that this channel is already switched on, it seems to get this feedback
this lets me conclude that there might be a way of detecting/reading the state of the relays as well ...
wouldn't it be cool to have Domoticz also know this state ?
how could this be done ?
Digital Active/Inactive
This is a 3 byte command:
The first byte is the command, 32 (active means on) or 33 (inactive).
Second byte is the relay number (1-8).
Third byte is the on time. Set this to zero for un-timed operation, or 1-255 for a pulse in 100mS intervals (100mS to 25.5 seconds).
For example:
0x20 - turn the relay on command
0x03 - relay 3
0x32 (50) - 5 seconds (50 * 100ms)
Board will return 0 for success, 1 for failure
Note - All bytes in a command must be sent in one TCP/IP packet .
I'm just a newbie in this, so hoping there are smart people who can help ...
Posted: Wednesday 17 June 2015 9:42
by nigels0
Any update on connecting the kLF100 to the eTH008? Just about to bite the bullet myself. I have 4 velux integra windows which I want to control as a group - both the window opening and the blinds - from what I read above, I need two KLF100s?
Posted: Wednesday 17 June 2015 17:07
by StanHD
Hi, I can confirm that my Velux windows work great with the KLF100 and ETH008
I have 2 windows in the same room, therefore operate them as a group with the KLF100.
Here's what works for me:-
1. Add dummy push-on switches for each "mode" with a 5s Off Delay setting e.g:- "Open", "Close", "Stop"
Address each switch to a relay on the ETH008 e.g.:
I use the HTTP Command:
Relay 1 = "Open".
http://192.168.0.33/io.cgi?DOA7 in the On Action of the switch, and
http://192.168.0.33/io.cgi?DOI7 in the Off Action of the switch
Relay 2 = "Close".
http://192.168.0.33/io.cgi?DOA8 in the On Action of the switch, and
http://192.168.0.33/io.cgi?DOI8 in the Off Action of the switch
The "Stop" Switch has no commands, just an Off Delay of 5s
2. Using the diagram provided with the KLF100, Connect the N.O. Contacts of Relays to the terminals on the KLF100.
3. I make another Dummy switch like this:-
4. I set the operating modes with a Blockly like this:
So when "Open" or "Close" is selected, the relevant switches operate the relays which set the mode of the Velux Windows. Unfortunately I have to use the separate "Stop" button as I do not know how to do it using the pre-defined "Stop" function available in the other Domoticz Switch. (If anyone knows how please let me know
5. Finally, I have made a control Blockly to "Automate" the windows on hot days:-
Hope this helps a bit. I am sure there are more elegant ways to do this with a script, but that would be beyond my skills.
Stan
Posted: Wednesday 17 June 2015 19:44
by nigels0
Stan
Thanks - really useful and comprehensive. I have four windows and will have them all as a group. Is it true then I'd need another kLF100 to handle the blind opening and closing for all 4 windows in the group operating together?
Posted: Wednesday 17 June 2015 20:23
by StanHD
nigels0 wrote:Stan
You are welcome.
I don't have blinds, so i am not sure, but yes, I think you would need another klf100.
Posted: Friday 19 June 2015 12:48
by nigels0
Just got the ETH008 and used your blocky and switches - didn't work though. Checked from the browser and was fine - so had to be password issues - so changed the script to http:admin:
[email protected]/io.cgi?DOA7=50 etc.) and all was fine. Note I decided not to use explicit on/off actions - rather let the board handle the switch off just to remove one possible fault with the ETH008 not receiving the off trigger (hence the =50 at the end).
Posted: Friday 19 June 2015 13:02
by StanHD
Ahh yes, I remember now, I turned off the password bit. If you come up with any better / different control methods, please share as you have done above. Nice to know I'm not the only one doing this
Posted: Sunday 21 June 2015 20:06
by nigels0
Well I changed the blocky to lua - that allowed me to remove a number of dummy switches. There is an outstanding issue with LUA which doesn't recognise 'Stopped', I have the code in there, but it doesn't work, so I have to keep the two Stopped dummy switches for now.
--script_device_velux.lua
--Works with two Velux KLF-100s to control both the Window open/close and the Blind up/down
if (devicechanged['Velux Windows'] == 'Open') then
os.execute('curl
http://admin:[email protected]/io.cgi?DOA7=50')
elseif (devicechanged['Velux Windows'] == 'Stopped') then
os.execute('curl
os.execute('curl
http://admin:[email protected]/io.cgi?DOA8=50')
elseif (devicechanged['Velux Windows'] == 'Closed') then
os.execute('curl
if (devicechanged['Velux Blinds'] == 'Open') then
os.execute('curl
http://admin:[email protected]/io.cgi?DOA5=50')
elseif (devicechanged['Velux Blinds'] == 'Stopped') then
os.execute('curl
http://admin:[email protected]/io.cgi?DOA6=50')
os.execute('curl
elseif (devicechanged['Velux Blinds'] == 'Closed') then
os.execute('curl
if (devicechanged['Velux Blind Stop'] == 'On') then
os.execute('curl
os.execute('curl
elseif (devicechanged['Velux Windows Stop'] == 'On') then
os.execute('curl
os.execute('curl
--print(devicechanged['Velux Windows'])
Posted: Saturday 11 July 2015 17:55
by nigels0
Well I got the two KLF-100 units connected to the ETH008 and programming the KLF-100 proved difficult; I had to de-register the windows and blinds as the KLF-100 did not 'see' them as they were registered to a remote control. Once I registered the windows and blinds to the KLF-100, I selected only the windows and they open and close exactly as planned. I then copied the config to the second KLF-100 and selected only the blinds - and they work fine too.
Posted: Saturday 11 July 2015 19:32
by StanHD
That's good. I think I used the "copy" routine from the existing remotes to register my KLF100.
Posted: Saturday 11 July 2015 20:13
by simonrg
Related question, I have 7 Velux solar blinds and 3 Velux electrically controlled windows, how many KLF-100s would I need to control them all?
Posted: Saturday 11 July 2015 21:37
by nigels0
You need one KLF-100 per group - so if you wanted to control all individually, you'd need 10 - but if you grouped some(or all) of the windows together and the same with the blinds - then you'll need just 2.And any other combination in between of course.
Posted: Sunday 12 July 2015 0:11
by StanHD
Yep, that's exactly right
