SMAspot multiple inverter support, gives only total production
Posted: Thursday 06 August 2020 16:42
by asenna
At home i have 2 identical SMA 5000TL inverters.
i import the data into Domoticz using SMAspot with one config file, in which multiple inverter support (MIS) is enabled. The data i get into Domoticz is all correct but i'm missing some stuff.
For example it shows me the total production , the sum of everything the inverters have produced until now (Kwh), in addition to the sum in hourly and daily times. Also the sum of the instantaneous production per minute (watts) is given
But i can nowhere see the productions (Kwh or watts) from the individual inverters.
The thing is that the roof layout for both inverters is very different. So it is interesting for me to see the production of both individual.
Can i add these 'productions per inverter ' devices somehow?
In the past I used 2 separate config-files and added up the production data to get to above totals (using a events script). But this MIS way of things looks like a more clean solution.
