Sonoff Touch T1 EU 3 Channel, physical button not working
FabianHD
Post by FabianHD »
I am having some issues with my Sonoff Touch T1 EU 3 Channel and was wondering if someone would find the issue.
My setup:
Hardware:
1x Sonoff Touch T1 EU 3 Channel
1x Sonoff Touch T1 EU 1 Channel
All a running Tasmota 8.4.0 with MQTT
I have not setup a light connected to channel 1 of the 3 Channel Touch and directly to the 1 Channel.
When I toggle the switch in the domoticz everything works perfectly, also when I toggle it via the webbrowser.
Only when touching the physical button on the 3 channel, it turns on the relay but does not turn on the light.
I have a similar setup with Channel 2 and 3 of the 3 Channel Touch and there is works perfetly fine.
Does anyone has any idea what the issue could be?
I also tried re-flashing both devices and giving new IdX numbers, without any success.
Emil01
Domoticz version: 2024.4
Re: Sonoff Touch T1 EU 3 Channel, physical button not working
Post by Emil01 »
I had issues with all my sonoff stuff and MQTT.
Finaly it was my accesspoint that was buggy. But while searching for a solution I came across this site: https://eye-vision.homeip.net/sonoff-s20-in-domoticz/
It solved a lot of issues for me and is working fine with the T1 and T4 switches.
Emil
Domoticz on Raspbery Pi and DeConz Zigbee.
Sonoff wifi (Tasmota) and Sonoff Zigbee. Lot of Ikea Zigbee sensors
FireWizard
Post by FireWizard »
@FabianHD
Did you check your "MQTT Client Gateway with LAN interface" setting "Prevent Loop"?
In your case this setting should be "False"
Screenshot_MQTT loop.png (29.8 KiB) Viewed 1600 times
