NAS Synology shutdown: how to
Posted: Tuesday 04 August 2020 9:48
Since most of the Synology NAS API are undocumented I thought it might be interesting to share how to shutdown Synology NAS using dzvents (currently running dzvents 3.0.9). Bare in mind that the user account used to log to the API has to be admin.
In order to have a general understanding of the Synology API, one might refer to https://global.download.synology.com/do ... eb_API.pdf
active = true, -- optional
devices = { 423 },
httpResponses = { 'sid1', 'endOfAction' }
data = {
sid1 = { initial = "" },
message = { initial = "" }
logging = {
level = domoticz.LOG_INFO,
marker = "syno script"
execute = function(dz, item)
local _u = dz.utils
local _h = dz.helpers
local _d = dz.data
local _ = dz.utils._
local function messageAdd (msg, msgNew)
if msg == "" then
msg = msgNew
msg = msg .. "\r" .. msgNew
return (msg)
if item.isDevice then
_d.initialize("sid1")
_d.initialize("message")
if item.idx == 423 and item.state == "Off" then
url= 'http://'.._h.saintPierreNasIP..'/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=2&account='.._h.nasUser..'&passwd='.._h.nasPass..'&session=mySession&format=sid'
dz.openURL({
url = url,
callback = 'sid1'
elseif item.isHTTPResponse then
if item.trigger == 'sid1' then
if item.ok then
if item.isJSON then
if item.json.success then
_d.sid1 = item.json.data.sid
-- send shutdown - for reboot replace shutdown by reboot
url = 'http://' .. _h.saintPierreNasIP..'/webapi/entry.cgi?api=SYNO.Core.System&version=1&method=shutdown&_sid='.._d.sid1
dz.openURL({
url = url,
callback = "endOfAction"
dz.log ("Looging error, cannot get SID")
dz.devices(423).toggleSwitch().silent()
-- TBD
dz.log ("API JSON malformed, cannot get SID")
dz.log ("Can't connect to NAS - statusCode = " .. item.statusCode .. " | status - " .. item.statusText)
elseif item.trigger == "endOfAction" then
if item.ok then
if item.isJSON then
dz.log("NAS shutdown initiated")
dz.log("NAS shutdown failed")
