Energy Meter and Notifications  [Solved]
Feybio
Post by Feybio »
Hi all :)
My energy supplier turns off the power if I exceed 3990 Watt for more than 2 minutes.
I created a Telegram notification to be alerted if this happens and works perfectly.
The energy meter reads the value every 5 seconds, the problem is as follows:
Values:
3512
3670
4001 (telegram notification)
3847
3798
As soon as I exceed the set value (3990) I am warned even if the subsequent values indicate that it was only a peak.
Is there a way, via script (lua, blokly ...), to receive the notification only if 2 or more consecutive values are greater than 3990 watts?
Thank you.
Raspberry Pi 3 and Pi 4 - Pi Camera - DS18B20 - HC-SR501 - FGMS-001 - Telegram Bot
Re: Energy Meter and Notifications
Feybio wrote: Monday 03 August 2020 8:55 My energy supplier turns off the power if I exceed 3990 Watt for more than 2 minutes.
Could look like
return
    on =
        devices =
            'Power', -- Change to name of your smartmeter
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = 'managed notification',
    data =
        consecutiveHighReads =
            initial = 0,
    execute = function(dz, item)
        local alertFence = 3990 -- change to your higfence
        local maxConsecutiveReadings = 2 -- change to max number of consecutive high reading.
        if item.usage > alertFence then
            dz.data.consecutiveHighReads = dz.data.consecutiveHighReads + 1
            if dz.data.consecutiveHighReads == maxConsecutiveReadings then
                dz.notify('Smartmeter','Power usage too high ( > ' .. alertFence .. ' ) for ' .. maxConsecutiveReadings .. ' consecutive readings.',nil,nil,nil,dz.NSS_TELEGRAM)
        elseif dz.data.consecutiveHighReads > 0 then
            dz.data.consecutiveHighReads = 0
Feybio
Post by Feybio »
Thank you, i got an error on line 29
2020-08-03 11:06:21.609 Error: dzVents: Error: (3.0.2) managed notification: ...Domoticz/scripts/dzVents/generated_scripts/Script #1.lua:29: attempt to compare number with nil
Feybio wrote: Monday 03 August 2020 11:06 2020-08-03 11:06:21.609 Error: dzVents: Error: (3.0.2) managed notification: ...Domoticz/scripts/dzVents/generated_scripts/Script #1.lua:29: attempt to compare number with nil
I assumed you energy meter is a smart meter. If you get this error it obviously is another type / subtype. Can you look at the devices tab to see what the device type and subtype of your energy meter is ?
Feybio
Post by Feybio »
Raspberry Pi 3 - Buster
Domoticz 2020.2
AEON Labs ZW090 Z-Stick Gen5 EU
AEON Labs DSB28 Home Energy Meter (2nd Edition)
Feybio wrote: Monday 03 August 2020 11:40 Raspberry Pi 3 - Buster
Domoticz 2020.2
Thx. Can you try with this one?
return
    on =
        devices =
            'Watts', -- Change to name of your smartmeter
    logging =
    data =
            initial = 0,
        if item.actualWatt > alertFence then
Feybio
Re: Energy Meter and Notifications  [Solved]
Post by Feybio »
Thanks a lot waaren, your script work perfectly!
Edit:
I need pls your help for the last implementation...
Its possibile to add another line after the notification is triggered that excecut a python script with a passed variable (actualWatt)?
Something like this:
- dz.notify('Smartmeter','Power usage too high ( > ' .. alertFence .. ' ) for ' .. maxConsecutiveReadings .. ' consecutive readings.',nil,nil,nil,dz.NSS_TELEGRAM)
- python /home/pi/Allarm/Script.py "item.actualWatt"
Sorry i'm very new to DzVents.
Feybio wrote: Tuesday 04 August 2020 7:52 I need pls your help for the last implementation...
Yes, could be something like
return
    on =
        devices =
            'Watts', -- Change to name of your energy meter
    logging =
    data =
            initial = 0,
        local alertFence = 3990 -- change to your highfence
                local cmd = 'python /home/pi/Allarm/Script.py ' .. item.actualWatt .. ' &'
                os.execute(cmd)
